19's killed fuel economy
evo2audi Jan 11, 2008
  1. evo2audi
    evo2audi New Member
    20
    Hi all, I recently fitted 19's to my whip. Car as in signature. They killed my power and seem to have hit my fuel economy hard. What gives ? Surely there isn't that much difference in weight. Anyone else notice this. I had 18's on before and there is a noticably difference when overtaking. I bent the 18's in the snow last week. Did not think 19's would affect like it has:wtf:
  2. andyccr
    andyccr 2003 1.8T Sport Ebony Black A4 Cabriolet
    442
    Went from 17s on my Octavia to 18s with no noticable difference.
    Also went from genuine 'old' RS4s to Sportec Mono10s in 19s and have noticed no real difference on fuel consumption
    Your signature says '19 RS4s' - are they cheap copies ? Maybe a heavier wheel than your originals ? What tyres ?
    A couple of variables for you to think about
  3. chris_20
    chris_20 Member
    707
    the 19s have a bigger rolling radius which in turn means the engine has to work harder to turn them. this obviously has a knock on effect of the fuel consumption but i must say ive never had any Noticeable difference.
  4. arthurfuxake
    1,308
    Sorry Chris, you could be wrong. 19" wheels with the correct size tyres should not have a significantly different rolling radius to 18" wheels. A shift from 18" to 19" wheels requires a drop in sidewall profile to compensate for the increase in wheel diameter. Our cars have varying diameter alloys as standard, but they are all the same overall rolling radius because the tyre profiles are different.
    Evo2audi, you say that you bent your 18" wheels in the snow, I'm guessing that was caused by an impact. Have you had the tracking and alignment checked? If the impact was big enough to bend the wheel, chances are that you've knocked the alignment out, if not worse. This might be causing the increased mpg's and will make the car feel slower, as one or more of the wheels is being dragged across the road rather than rolled.
  5. chris_20
    chris_20 Member
    707
    Thats what i meant ^^ lol
  6. evo2audi
    evo2audi New Member
    20
    Had it aligned. no problems there. As you said the sidewall has decreased to compensate for the increase in size. can't figure it out
  7. J7USS
    J7USS Shuddup Foooool!!
    3,737
    77
    What are the offset of these 19's??
  8. evo2audi
    evo2audi New Member
    20
    Not sure of the offset to be honest, forgive my ignorance how does the offset affect the economy/power ? please explain?
  9. J7USS
    3,737
    77
    If your offset is well out then you car feels like its running on Wooden Wheels, Hence the slowness in Roll etc (this can also be to do with your camber etc) and when you let your led foot off the accelerator it just feels like it wants to slow down if you get what Im sayin, Just general drive feels like ***** basically! You say you have had a wheel alighnment - I take it a Proper one, Not just a Kwik fit drive on Jobby!!
    Optiflex machine is what you need.
    ....Well me scooby did when my offset was totally wrong..
    Felt like I had to really give it some to get that feeling you used to get with standard wheels on.
    Im going on Power wise, I aint talking about economy because I took them off after 20miles or so..
  10. evo2audi
    evo2audi New Member
    20
    Proper alignment. Proper 4 wheel jobbie. Don't know what is going on. I went from 17 to 18 on my Evo and noticed no difference at all.
  11. ChuckH
    ChuckH Member
    159
    What He means is that as the size of the rim goes up The depth of the sidewall of the tyre generaly decreases
    So in effect the overall outside diamiter of the wheel/tyre combo should remain the same !
    There is no real reason why Your wheel swap should adversley affect the fuel economy !!
  12. terrysingh
    terrysingh Member
    184
    heres the techy bit, the reason your car runs worse on 19" compared to 17" and 18" is the wheels rotational mass changes i.e. where the was rubber and air there is now metal, causing a drag on the engine hence the drop in performance and mpg....
    so i've been told?
  13. dan_b
    dan_b Member
    263
    I'll add to the above with a few pointers.
    Are the brand of tyres the same? A more sticky tyre should in theory reduce MPG.
    Also, are the new tyres wider than the old 18s? Again, with more rubber in contact with the road, you've got more drag, therefore poorer MPG.
    In addition, is the rolling radius actually the same (ie. are you sure you've got the correct profile ratio on the new tyre)? As above, a bigger diameter will not only give a bigger rotational mass, but also a longer contact patch on the road, which will as before reduce MPG.
    On top of that, the newer wheels themselves may be just a bit heavier - that extra inch diameter of metal could well weigh a bit more. Again you're into increased rotational mass there.
    Finally (phew!), check your tyre pressures - low pressures can reduce MPG.
  14. evo2audi
    evo2audi New Member
    20
    The tyres are continental. the pressure is spot on. guess if i want the look that is the compromise. something to bear in mind for all you out there. Incidentally what pressure are you 19" boys runnin ?
  15. J7USS
    3,737
    77
    36 rears,34 fronts..
  16. golf
    golf ***** rent boy VCDS Map User
    1,556
    I run 36 PSI all round.
  17. dan_b
    dan_b Member
    263
    All sounds ok then - are you sure something else didn't get knocked/ damaged when you kerbed the wheels in the snow? Perhaps a sensor has come off, or something is on the blink?
