1999 fwd front wheel bearing
jas828 Mar 25, 2013
  1. jas828
    jas828 Member
    42
    think ive got a front drivers side wheel bearing on its way out got a lancaster aeroplane noise going on about 40-60mph and when i go round left hand bend so that side is loaded right up its goes quieter do the bearings need pressing in/out etc ?or anybody got a guide to doing job ?
  2. aragorn
    17,956
    701
    yes bearings require a press or similar.
    Before you take it apart, spin each wheel with the car jacked up, the faulty one will sound rough.
  3. jas828
    jas828 Member
    42
    ok will jack it up in a moment on other cars ive used old sockets etc and studding and nuts to draw bearings in and out is this trick doable with these bearings ?
  4. aragorn
    17,956
    701
    Possibly, but the Audi bearings have no circlips and are a very tight interference fit. Some can need 5+ tonnes of pressure to shift the old bearing, and most i've done seem to need a couple of tonnes to press them back in.
  5. jas828
    jas828 Member
    42
    just checked both front wheels no play no noise i put a new track rod end on recently and know tracking is out im due two tyres and tracking in couple of weeks is it possible its tyre noise as front right tyre is one that is out on tracking ?
  6. aragorn
    17,956
    701
    check the rears as well?
    It wont be loud, it'll just have a slight rumble to it.
  7. Nessy
    Nessy VW + Audi mad
    835
    56
    I managed to change the (similar-looking) front bearings many years ago on my Series 4 Audi 80 with a couple of drifts and a very big hammer,lol, but when I did the same job on my present A4 I used a hydraulic press, as Aragorn says they are a very tight interference fit.
    Getting the old ones out and new ones in took almost 5 tonnes of pressure as stated, there's no way IMHO you'd do it without hydraulic assistance.
  8. jas828
    jas828 Member
    42
    ill jack up again tomorrow but all i could hear spinning front wheels was slight drag of brake pads as normal
  9. Nessy
    Nessy VW + Audi mad
    835
    56
    When I did the fronts as mentioned above there wasn't a lot of give/feel evident in the bearings until I was able to press them out of the hubs.
    When they were removed they appeared very very rough and most definitely clapped-out....
  10. jas828
    jas828 Member
    42
    nessy think that what wrong with mine cant feel anything but its def noisy from drivers side
  11. jas828
    jas828 Member
    42
    been under again and found split boot on cv and over last couple of weeks get a small clonk on taking drive up could this also be my prob at speed when running aswell a worn cv joint ?
  12. Mike_B
    Mike_B Active Member
    533
    47
    FWIW I had the "drone" of a dud bearing a few months ago and couldn't diagnose which side it was by "spinning the wheels" - even the garage couldn't be 100% sure which side it was and it didn't make any real difference whether it was loaded left or right. Mike
  13. jas828
    jas828 Member
    42
    mike did you have both changed in the end ?
