1999 A6 1.8T Coolant Temp Gauge Problem
N22CKS Mar 5, 2011
  1. N22CKS
    N22CKS New Member
    Hi Guys, just after a little help here.
    When i turn on my ignition the temp guage picks up a reading, but as i drive it drops down to 60 degrees as though it is not working?
    I have also noticed that the oil temp gauge doesn't move either.
    Today i changed the coolant temp sensor but the problem is still there. I can keep my foot on the accellerator and the gauge will go up to 80+ degrees, but once i release the accellerator it will return to 60 degrees?
    I have bought a thermostat but havn't got round to fitting it yet. Do you think this may fix the problem, or could it be electrical?
    Any help appreciated.
  2. kite
    kite Member VCDS Map User
    677
    I would suspect the stat.
  3. crispin
    crispin Member
    167
    I would say thermostat too..
  4. N22CKS
    N22CKS New Member
    Thermostat fixed the problems guys thanks.
    Both the coolant and oil gauges now opperate as they should.
