1998 s4 avant aircon fault
judgey Jun 26, 2009
Thread Status:
Not open for further replies.
  1. judgey
    judgey New Member
    recently had aircon checked as it is not working the garage said this the pressure was increasing on its own and this should'nt happen he blamed it on stuck clutches in the air con compressor expensive big job so id like to be sure ive since been told that if the fans arnt spinning this can cause a fault on my s4 it has 3 fans 2 on rad left and right and one grille side on condensor rad the one on the left in the engine bay sometimes trys to turn but cant is this the likely aircon fault and does anyone know the sequence this fans work in thanks
  2. Staz
    Staz is a retronaut Staff Member Moderator VCDS Map User
    6,206
    64
    Dude you need to learn how to punctuate! That is pretty hard to read.
    When you first turn the engine on there will be no fans running (without air con on) then when you turn it on the condensor fan should start.
    Stuck clutches in the air con compressor? What? Ok get someone in the car to press the ECON button on and off while you look and listen in the engine bay. You should see/hear the compressor clutch popping in and out.
    Try a specialist a rather than a normal garage.
  3. judgey
    judgey New Member
    firstly i didnt ask for an english lesson i asked for advice and to be honest yours was no help cheers anyway
  4. Staz
    6,206
    64
    You didn't ask, but I was telling.
Thread Status:
