1998 Audi a3 1.8t agu
Timmsyh Aug 29, 2013
  1. Timmsyh
    Timmsyh Member
    32
    Right im new so hello guys hope to get to know some and maybe join some of you at some shows .
    So where do i start i have a audi a3 1.8t agu and iam going to start tuning first of some one told me this.
    Saab red top injectors and 3" MAF housing so thats whats happening ive broght the injectors and my uncle is a cnc machiner so he's going to machine me a new housing out of alloy first question is .. will i need to replace all the intake pipes to the turbo for it to benift ? and..
    they said i would only need the injectors and maf no remap is this correct ??
    I will also post a thread very soon of my progress so far
    im going to open my airbox hole a bit bigger to fit new housing in and then seal with a sealant as i think i will loose the o'ring
    thank you guys !
  2. Lewis583
    956
    91
    Must do modifications K03/K03S AGU/AUM
    They are wrong, 3inch MAF housing not reqd unless you are swapping to a K03S. Same with the injectors, I think.
    Have a read through the above thread which goes into lots of detail the stages/mods needed etc
  3. Timmsyh
    Timmsyh Member
    32
    That's a brilliant thread but it doesn't really help me I need to know if I can put these injectors in with a 3" housing without a remap and without changing any other pipes :(
  4. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,184
    No. You can't.
    Larger MAF = more surface area and more air being read. Larger injectors means more fuel.
    It will blow up within a mile.
    If you'd read my post you would see where I say "DO NOT FIT THE MAF AND INJECTORS" and explain the reasons why.
    Xxx
  5. Timmsyh
    Timmsyh Member
    32
    Perfect thank you :) I did read it must have missed that bit
  6. 16Klappe
    5,795
    1,184
  7. Timmsyh
    Timmsyh Member
    32
    Ahhh ok so get my new maf made still but wait untill ko3s remap upgrade ?
    If I get a maf made that goes 3 inch intake maf sensor then decrease to fit my current intake pipe will this still work or does it need to be 3" the whole way through ?
  8. 16Klappe
    5,795
    1,184
    Why are you getting a new MAF "made"?
  9. Timmsyh
    Timmsyh Member
    32
    To fit my standard air box as I was told keep it and put a pipercoss filament in it
  10. 16Klappe
    5,795
    1,184
    Oh Jesus :(
    Who told you this?
  11. Gops
    3,198
    666
    Hi bud.. Just a quick thing to consider.. And I'll say this so you don't mess your car up..
    FIRST RULE OF ASN: forget what you was told, it's more than likely wrong.. Read jardo's thread posted above and Learn from that. Some deep thought and years of experience is in there and worth more than gold!
    2. Do It right first time.. Don't put cheap things in these cars. I know they're not worth much nowadays but they were £15k+ when new so they still require the best! That doesn't mean you need to spend top dollar.. It means read though a few threads and find that you don't need to spend £300+ on a carbon fibre F1 style induction.. £14 will get you a s2000 filter, proven to give better gains.
    3. Don't take things personally.. We're all trying to help and make suree your on the right path rather then ending up with a car that's blown up!
    Hope this helps.. Good luck :thumbsup:
    Gops :)
    16Klappe and vivalacoulter like this.
  12. vivalacoulter
    vivalacoulter Active Member VCDS Map User Gold Supporter Audi S5
    408
    60
    This thread is very confusing. Can't we all start again?
  13. 16Klappe
    5,795
    1,184
    Yup, S2000 air filter ftw. I have seen 500bhp+ Honda S2000's with the standard air filter used in one form or another. Very good flow and great value for money, you could buy three S2000 filters for the cost of one aftermarket filter.
    Chances are you will have sold the car before you replace the standard filter once a year three times.
    I lol'd at this thread and showed another very famous face on this forum earlier, and he asked me why I bother. I bother because I care :) Thanks Gopal.
    I don't claim to know everything, but what I do know certainly works and works well. We've all been there, luckily for me I have great friends who helped me in the way I try to help others, so I did everything right the first time.
    :beerchug:
    Gops likes this.
  14. Timmsyh
    Timmsyh Member
    32
    Don't worry I won't take it personally that is why I came on here Iam completely new to these turbos , I do want people to say don't do that do this but I just wanted to clear up on what I had been told
    :D Iam very grateful off all the information you guys can give me Iam here to learn
