1998 A4 concert radio/cd player not working
zeeshan Jan 14, 2008
  1. zeeshan
    zeeshan New Member
    Hi,
    I had to get my battery replaced so the radio got locked. I have tried to get it out with the tool but it got stuck and didn't come out. While trying, I think I have snapped a clip or something inside the right-hand side hole to put the removing tool in. Now it wont even power up. It powers up if i push the radio in really hard.
    Anyone got any idea whats wrong with it?? I'd really appreciate some help. Let me know if you didnt really understand wot i said up there i can explain even further.
    Cheers!
  2. AndyMac
    9,832
    45
    Why were you trying to get it out, Audi can supply the code for £30?
    Yes you've snapped or bent one of the spring clips.
    You need to remove the glovebox and push the unit from behind.
    Alternatively you can prise off the front of the unit which will give you more access to the stuck clip. But basically a real hard push from behind is probably an easier route.
  3. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,772
    32
    If it powers up when you push the unit hard, it sounds like you may have a loose connection at the back.
  4. zeeshan
    zeeshan New Member
    Thanks for your replys
    I found the software to get the code but i needed the serial number thats written on top of the radio.
    I went to the stealers and they said it'd be £50 to have a look at it and If i've broke something inside than there will be an extra charge for replacing it so that scared me off a bit.
    I will try pushing it out from the back and see if i can get it out but how do i replace the spring clip. it seems that it wont trun on unless its properly clipped in.
  5. AndyMac
    9,832
    45
    The clip is nothing to do with it turning on, by pushing it back in you're bunching up the cables at the back and making a connection on the power loom.
