1998 1.6 Sport stuttering while accelerating hard and high idling
Mayhem Jun 7, 2008
  1. Mayhem
    Mayhem New Member
    Hi,
    I have an S reg Audi A3 1.6 Sport and have been having a couple of problems with it.
    The first problem is that when I start the car the rev counter stays on about 1200rpm for about 5 minutes and then goes back down to normal (about 900rpm). If I turn the ignition off and turn it back on it is fine but the problem is there if it is hot or cold outside. This is not a big problem but it is annoying as the car almost stalls when the revs go back down after 5 minutes. I have had this problem for pretty much six months since I got the car.
    The second problem seems unrelated to the first as it has only been happening over the last 2 weeks. The car has been stuttering or to put it another way 'bunny hoping' under medium to hard acceleration in gears 1 and 2. It does not stall when this happens.
    The only thing that might be causing it is that I changed from getting my petrol from the Esso garage that I normally go to to a Tesco's garage.
    I have read on forums about coil packs and cleaing the air filter might fix the problem but I really don't know much about cars, although I have taken the whole front of my A3 off to change the electric fan once so I'm not afraid to work on the car if anyone has any suggestions as to what might fix these two problems.
    Also no warning lights come on the dashboard!
  2. Mayhem
    Mayhem New Member
    Also forgot to mention, when I accelerate hard sometimes it feels a little less powerfull than normal as though it is not accelerating as fast as it should.
  3. Shy19s
    Shy19s Oil running through my veins.
    886
    check your vacuum pipe that comes off the rocker cover and connects at the intake pipe near the throttle body.
    The other thicker pipe that is near this one also...these commonly perish on the 1.6 engines as oil travels through this pipe.
    While you've got the engine cover off you might as well clean your throttle body, its only 4 bolts and it pops off. Carb cleaner, rag. recommend to any car. especially the VAG range.
  4. Mayhem
    Mayhem New Member
    Thanks Shy19s I'll give that a try today
  5. dr3w000
    dr3w000 New Member
    Did you ever resolve this as i have the exact same problem on my a3 1.6?
  6. TheSpaceCowboy
    TheSpaceCowboy Member
    520
    High idle sounds normal, my car sits for approx. 3 minutes on fast idle (around 1,200rpms) until the car gets temperature.
  7. Mayhem
    Mayhem New Member
    Yes I sorted out the stuttering problem. It was mainly a faulty spark plug. For a few days it was going really slow. I have replaced the coil pack, all four spark plugs and all four ht leads. I got all the parts off ebay for about £10 each. When I went to replace them I found one of the spark plugs had a lot of petrol on it so that is what had caused the loss of power and stuttering. The ht lead attached to the spark plug looked pretty bad aswell. I didnt need to replace the coil pack but the new one did make it run even better and at £10 off ebay it was well worth it. Replacing the spark plugs and ht leads on my A3 with engine code AVU was a nightmare though, had to remove the lower section of the the variable inlet manifold and ht leads are easily damaged when removing them.
    As for the high idle, you are right TheSpaceCowboy, I have been told this is totally normal, shows how much I know about cars!
    I also checked the vacuum pipe and that was ok, I didnt touch the throttle body though-seemed a bit too complicated from the guide in the haynes manual.
  8. Clach
    Clach A3 - 1.8Ts
    971
    I didn't know the 1.6 came as a 'sport' any pics...?
  9. Dubturbo
    Dubturbo VW Golf mk2 20VT / Audi A3 1.6 Sport
    26
    I have a 1.6 Sport as well, they're practically identical to the 1.8 Sports, same checked interior, sports steering wheel, 6 spoke 15" wheels etc :)
  10. Clach
    Clach A3 - 1.8Ts
    971
    Oh i see, although my turbo sport 1.8 has 16" spoke wheels...good upgrade from 15's as you can get them now for £50 on flea bay...
  11. Mayhem
    Mayhem New Member
    Its def a 'Sport' model, I should have got a 1.8 Turbo instead though-Live and learn!
