  1. moneyman
    moneyman New Member
    My son is about to purchase a 1996 A4 with less than 13,000 actual miles. I know your first question -- yes we have verified that the miles are indeed actual. The car was only driven sparingly in the summer months by elderly lady who went south for the winter.
    My question is what the experts on this board would recommend for tuning up this car. Currently we plan to change all fluids based on age alone. Also the plugs so as to not get seizure at some later date. Still undecided is the timing belt/water pump?
    You thoughts on what we should do would be most appreciated. Thanks
  2. RichA3Turbo
    RichA3Turbo ...Watching you! Moderator
    5,089
    [ QUOTE ]
    [/ QUOTE ]
    What engine is in it?
  3. dann959
    dann959 Member
    91
    you should not have to worry about the timing belt or water pump since that deals more with miliage rather than age.
    As far as tuning up goes do you mean performance upgrades or just making suret the car is in good running order?
  4. moneyman
    moneyman New Member
    The car's engine is the 2.8. My goal is to just do a regular tuneup, although I am sure my son will be in touch with everyone in the future to get info on performance upgrades and chips.
  5. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    There's not a lot you can do with the 2.8 in terms of chipping or modding for additional performance. Is it the 30 valve or 12v?
  6. Patrick
    Patrick Member
    153
    TIMING BELT TIMING BELT TIMING BELT a 1996 i.e. 8 year old V6 going into the hands of a young lad REV REV REV it has to have a new timing belt as theeeee highest priority!!
    Who hasn't heard of the horrors of a snapped timing belt? Especially when two heads are concerned! Rubber perishes millage or not!!!
    Yeah a complete fluid n filter change. If the previous owner was canny on it, I would also drive the car like you were running in a new one for the first couple of hundred miles. It's going to be a big shock to everything to suddenly be exposed to full performance. I am of course being presumptuous that your lad is the same as 90% of young lads behind the wheel and enjoys a spirited run /ubbthreads/images/graemlins/smile.gif Enjoy!
    The thermostats, brake discs n pads may not be at there best so give her a chance to adjust and let you know if something is not right.
