1996 A4 Clutch Problems !!!
Benner3 Nov 27, 2011
  1. Benner3
    Benner3 New Member
    10
    Hi everybody ! Just joined this site + thought I'd find out everybody's opinions on clutch problems I'm having. Clutch pedal free travel has increased (engaging point is lower to floor) and difficult to get gears. Also whirring noise when clutch pedal depressed.
    Slave cylinder was replaced 3 mths ago and system bled. Any ideas as to how far down clutch should engage and what's causing this ?
  2. Bradderz_1988
    3,958
    240
    What engine do you have ??
    Your only way to really find out is to whiz the gearbox out !!
    Also dual mass flywheels are problems to start of with.
  3. Benner3
    Benner3 New Member
    10
    Model is basic 4 door with 1.8 engine (code ADR).
  4. Bradderz_1988
    3,958
    240
    Whirring noise could be the release bearing.
    When the clutch is pressed is there any judder/vibration through the pedal/car ??
    I've seen this sort of fault many of times at work on the Citroen C1 were the clutch pressure plate breaks of one of the plate retaining spring/fingers
  5. Benner3
    Benner3 New Member
    10
    No judder/vibration through the pedal/car when the clutch is pressed. I also think whirring noise is release bearing so I guess it's probably going to be gearbox out and complete clutch replacement job ! Although I'm also wondering whether master slave cylinder has anything to do with it ?
