190 merc mono blocks??
simers Dec 15, 2013
  1. simers
    simers Member
    140
    21
    Will these fit on my A4?? They are 18's
  2. quattrojames
    14,050
    573
    My encyclopaedic knowledge of wheels is failing me here.... What is the offset and PCD etc? You want 5x112, 57.1 centre bore and an offset of 30-40 unless you love spacers..
  3. simers
    simers Member
    140
    21
    All I no is the 190 merc is 92... Think the centre is 50mm so how do I work that out or just leave them?? They really cheap too
  4. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,695
    156
    Mercs do run 5x112 pcd and the ET aren't a million miles away from Audis depending on the alloy. A lot of A8 owners fit Merc Monoblocks. Iirc the bore is something like 61mm so you may need spigot rings to seat the wheel correctly.
    So as long as the ET is somewhere near like mentioned above then yes they will fit.
    Dan
  5. simers
    simers Member
    140
    21
    Centre bore is putting me off as I dunno how to counteract that
  6. S4_dan
    2,695
    156
    If the merc bore is bigger, then spigot rings will be needed. If it's smaller then you will need to rethink or change the Audi hubs......
    just found this...although not 1992, starts from 1993
    190 W201 95 to 93 5x112 35 to 42 66.6
    66.6mm bore. Spigot rings will be your friend to make these fit.
    Dan
  7. simers
    simers Member
    140
    21
    It's 50mm centre bore... Think I'll leave them where they are then
  8. ajax1976
    ajax1976 Well-Known Member
    1,257
    649
    Any decent machine shop would be able to machine them out to 57.1 no probs at all. I got a set of 4 wheels done for £20 not that long ago at a local place to me.
  9. simers
    simers Member
    140
    21
    Cheers mate... The wheels are only €150 with 40% tires but they better than my own at the minute
