19" wheels with 235/35/19 tyres any rubbing issyes?
Kash3838 Oct 7, 2011
  1. Kash3838
    Kash3838 Member
    185
    19
    i wabt to upgrade my s3 8p to 19" alloys - 8.5 x 19 et45 with 235/35/19 tyres
    will they cause any rubbing on front and rear with standard suspenion set up?
  2. bagey
    bagey aud you do !
    198
    if you dont lower it you "shud be ok " fella , its the rear that will rub the most
  3. moag
    moag she's no d-turbo
    821
    35
    is your car lowered?
    I have 235 on my front but had to change the rears for 225 when i lowered 45mm
  4. Rob-Quattro
    Rob-Quattro Member
    225
    13
    I have a standard ride height s line and fitted 19" with the same tyres and not had any problems. Does make the car look even higher though! You can lower it without rubbing aslong as you have 215 35 19's fitted (225 if your not decking it)
  5. Ash B
    Ash B Well-Known Member
    5,831
    84
    As said fella you will be fine on standard set up. Sure N8 will be along to confirm anyway. What alloys you getting? I see your car quite alot parked outside your company looks good ;)
  6. Kash3838
    Kash3838 Member
    185
    19
    It's standard set up, dunno about lowering it..... Hmm
    If I do I'll opt for 225 instead. As fir the rims there are a couple I like. Not 100% sure yet.
    I think I'll get the Tyres in 1st.
  7. Kash3838
    Kash3838 Member
    185
    19
    Ash seen ur car too, looking good. I'm getting bored so need to do something to the car.
  8. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,405
    546
    IMO if you are fitting 19s you will have to lower it as it will look like a monster truck!
  9. N8
    17,163
    718
    215s ADL.
  10. Kash3838
    Kash3838 Member
    185
    19
    Boydie, what profile Tyres u running on ur s3 with the bbs's?
  11. N8
    17,163
    718
    235/35/19s
  12. Kash3838
    Kash3838 Member
    185
    19
    sorted, h&r it is then! cheers!
  13. N8
    17,163
    718
    His wheels are 8J and ET50.
  14. Ash B
    5,831
    84
    Cheers fella. We will have to arrange an local 8P meet soon. Get some photos up once your done :) a
  15. Kash3838
    Kash3838 Member
    185
    19
    aah... Might have to go with 225 if i decide on 8.5 x 19 then....
  16. N8
    17,163
    718
