19" wheels on a6
madluke Dec 3, 2010
  1. madluke
    madluke In pursuit of audiness:)
    276
    Hello
    Recently i bought a6 2.7 tdi 06 sline. id like to get 19" wheels on it they called a6 speedline (a lot of spokes) but i need advice with size 8j,8.5j or 9j and what offset and finally
    what tyres size to make archers filled nicely and no rubbing?(ive seen a lot of a6 with these wheels and they match archer line so nice) Please advice me:)
  2. madluke
    276
    nobody??
  3. Cockney Boy
    Cockney Boy Member
    483
    I have 19" S5 Alloys on mine, and the are 33 offsets, so they do stick out a little but dont rub. If you get a 35 offset of greater these will fit inside the wheel arch nicely
  4. madluke
    276
    thanks for reply. what tyre size do you have? im about to order rs4 19" et35 and possibly tyres 245/40/19 will they fit?
  5. Gavin0478
    Gavin0478 Active Member Team Daytona Team V8 VCDS Map User quattro Audi Q7 TDi
    520
    39
    255/35/19 is the norm
  6. madluke
    276
    will i have any rubbing problem with 255/35/19 and et35 wheels?
  7. Garpemo
    Garpemo Member
    33
    If you have S-line will 255/35/19 rub on 8J ET35?
  8. Garpemo
    Garpemo Member
    33
    Forgot to tell on a 2004 A6 3.0 that is.
  9. Ben jah min
    Ben jah min Member
    162
    22
    Running 19" speedlines on your A6 is doable, although if you've not sorted the ride height it will look like a tractor. Obviously depending on how low you go effects what ET and tyre choice you make.
    Are you running standard ride height?
  10. Garpemo
    Garpemo Member
    33
    Yes. It's factory lowered S-line. I've noticed that it's lower and stiffer.
  11. Garpemo
    Garpemo Member
    33
