19" tyres... where do you buy yours from?
Ash187 Aug 30, 2012
  1. Ash187
    7,496
    744
    I have been looking around to getting some 19" alloys but i am having trouble finding a set of 225/35/19s for a decent price... i mean yeah i know 19s are going to be more expensive but £600 on a set of tyres alone is ridiculous!
    Does anyone have a good suggestion of places i can find a set of 225/35/19s in maybe the Avon ZZ3 or Falken FK452? i have heard good things about those tyres which are fairly well priced.
    Best price i have found so far is Camskill who have the Avons at £109.20 each or the Falkens at £117.50 each
    thanks
  2. N8
    17,163
    718
    Camskill.
  3. Brodster
    Brodster Well-Known Member Team Ibis VCDS Map User Audi S4 Audi Avant Owner Group
    3,548
    886
    Exactly what I was gonna say N8. Ash I've got the Avons fitted to my S3 and I can't fault them at all even on the 19's
  4. brasiliangringo
    brasiliangringo Member
    626
    10
    I started using Camskills until i found Blackcircles which were cheaper when i used them.
  5. PH1L
    PH1L Gievf Buckets
    3,851
    40
    ill let the guru deal with this he will be along shortly but running stretch degrades performance anyway avons are normally good as are the falkens, tyres are an expensive business dude
  6. Ash187
    7,496
    744
    so your saying i should be running 235s?
    i have always thought the 235s on a 8.5 wide wheel et45 would rub? thats the only reason i was thinking the 225 tyre
  7. mjr901
    mjr901 Guest
    Do you know if tyre companies are going to bring out the tyres with white writing on the side? Heard this to be true but cannot see any at present. think it was goodyears?
  8. Brodster
    3,548
    886
    Hope not. Think that would look too Chavvy even on a white car.
  9. Brodster
    3,548
    886
    Mine are ET44 and rub slightly when going over bumps/dips. Taking the screw out of the rear arch liner helped alot. Does it now and again if I have the kids in the back.
  10. N8
    17,163
    718
    Negative camber will solve rubbing problems.
  11. Ash187
    7,496
    744
    ideally i dont want to mess about with the camber... also i will be dropping the car on Eibach sportlines so i want to get it right now before i start ordering bits
  12. Ste_Nova
    Ste_Nova Active Member
    1,223
    47
  13. moag
    moag she's no d-turbo
    821
    35
    225s ash. I had to change from 235s on my 19x8.5 ET45s, on h&r springs
    Camskill are usually the best priced
  14. pinterovski
    pinterovski Member
    667
    88
    With 235's on 19's et45 8.5J you gonna rub,specially when lowered!
    With 225 you can even get a slight rub! Remove the rear arch screw and the front
    or buy ET48 Wheels.
  15. Ash B
    Ash B Well-Known Member
    5,831
    85
    As most have said Camskill. Will be ordering a set of tyres off them this weekend.
    An get 225 tyres
  16. Ash187
    7,496
    744
    ok wicked! 225s it is!
    I cant find the alloys i want in ET 48 plus i want them to sit nicely along with the arch...
    now just need to find the right deal.
    so what would you rate better... Avon ZZ3 or Falken FK452?
  17. Brodster
    3,548
    886
    They're both good tyres for the price. Never had Falkens on any of my cars so cannot comment on them. The Avon ZZ3's are good as I said before. Great tread pattern and I find them very good in the wet........and we've had a lot of that up here lately.
  18. MartayMcFly
    MartayMcFly Booooooost VCDS Map User Gold Supporter
    2,763
    354
    Camskill 225/35 R19 Falken 452s on mine... can't fault them. Best price and quick delivery.Obviously the Falkens aren't as good as Contis, but much better value for money. Avons wear quite quickly in my experience, but are great in the wet.
  19. Ash187
    7,496
    744
    good point Marty... i need something that isnt going to eat through rubber as i do massive mileage. dont want to be forking out the £450 every 8 months
