19" tyre recommendations please...
maars Jan 4, 2011
  1. maars
    maars Full speed ahead
    576
    So, two years and about 20k miles later, the tyres on my A3 TDI quattro are shot - currently Goodyear Eagle F1 Asymmetrics, 225/35x19, stretched on 8.5x19 BBS alloys.
    I was pretty shocked at their eventual demise...parked up one night to hear hissing from the front right. When I took the wheel off the inside edge was worn away at 45 degrees and the tread has started coming away from the bead! A trip to my local tyre fitter confirmed that the other front tyre was ready to split and the backs were well on their way.
    Question is, what caused the tyre failure? I've never had a tyre wear/blow like that before. Age? Stretching the tyre on the 8.5" wide rim? Tracking perhaps? The car is lowered but the wheels are the correct offset, there's no rubbing and it doesn't pull to one side.
    The garage recommended fitting 235/35x19s but they would appear to have the wrong diameter compared to the OEM 225/40x18s (see visual-tyre-size-calculator).
    So what to do? Go with F1s again (£170 a tyre)? Or a cheaper alternative? Thoughts please...
  2. Smoothie
    Smoothie Active Member
    1,431
    not sure about the tyres mate but wouldn't mind seeing some pictures of your car, sounds nice from your signature lol
  3. N8
    17,163
    718
    Maars I got 2 brand new Falken 225 35 19 for sale if your interested.
  4. maars
    576
    Loving those German plates Smoothie - must get mine ordered this year! Here's an old pic of the car...
    N8 - thanks for the offer. How do you rate the Falkens? PM me with price, etc.
  5. tku
    tku Member
    630
    If you want to go cheaper option but good for the money go for falkens as they are ridiculously good value. If your going for premium then go michelins!
  6. devonmikeyboy
    devonmikeyboy As far from JBS as possible !
    1,245
  7. Paul_S3
    Paul_S3 Member
    114
    22
    Do you have a picture of the 225 tyre on these rims showing how much the tire is stretched?
  8. Ads
    Ads License to drive
    8,230
    608
    Falken FK452 are very good tyres (I'm running them at the moment) and very reasonably priced.
    Only negative is that I find them to be very noisy, especially on older road tarmac.
  9. Lee_R
    Lee_R Active Member
    2,499
    12
    Stretching isnt ideal for the daily grind, small stretch shouldnt be too bad though but at the end of the day, they are not designed to be stretched so the side walls eventually give way
    Falkens are good choice, i'd either have them or kumho's. Also good value
  10. Paul_S3
    Paul_S3 Member
    114
    22
    Stretching in not good indeed but 225 on 8.5J rims isn't that stretched so I was wondering how this looks so a picture would be very very helpfull
  11. N8
    17,163
    718
    Stretch is fine on the daily grind
  12. Smoothie
    1,431
    Cheers mate, car is looking well always liked the splits, big brakes always look good with them
  13. IanMcA3
    IanMcA3 Member
    59
    maars - out of curiosity were the Goodyears "eXtra Load" rated. Glad to hear it didn't let go whilst you were at motorway speed!
  14. Synchromesh
    Synchromesh :-)
    98
  15. I oOEddOo I
    I oOEddOo I Member
    340
    15
    Bridgestone Potenza R050A
  16. maars
    576
    Yes, I think they were - they were the 88Y version. Supposedly these have reinforced sidewalls?
  17. maars
    576
    Thanks for all the help guys. I have a few leads on some cheap F1s - best price so far is £140/tyre. Considering a set of Falkens if I can't source the F1s again.
    Had to laugh at Audi, who wanted £280 for a four wheel alignment (because it's a quattro). Phoned around and most of the decent tyre shops offer the same service for £50!!
  18. maars
    576
    Here's a pic of the offending tyre...note the wear on the inside edge, and the nice split...
  19. N8
    17,163
    718
    If you want these Falkens James lemme know man!
  20. maars
    576
    Will do N8...all depends on if I can/can't get the F1s sourced in time.
  21. Lee_R
    Lee_R Active Member
    2,499
    12
    Wear like that is the norm if your wheel alignment is out, get it sorted when you get your new tyres. However exactly the same happened to muy 2 front tyres because lowering the car adjusts the camber slightly and that coupled with the heavy TDI block means front tyres get scrubbed up easy on the inside.
  22. Paul_S3
    Paul_S3 Member
    114
    22
    That looks serieus.
    DO you have a picture like this, but then the outside of the wheel so I can see how much the tire is stretched on that side?
    thanks
  23. maars
    576
    I dont' have a side profile shot - I'll take one at the weekend. From memory the stretch is a little less on the outside that the inside, but that might just be an optical illusion. The fronts are much worse than the rears, and yes the car is lowered. But the tyres have done well otherwise - 20k miles over two years, and they've all worn evenly otherwise.
  24. Paul_S3
    Paul_S3 Member
    114
    22
    thanks, looking forward to these pics.
  25. maars
    576
  26. maars
    576
    Decisions, decisions! Seems everywhere (in the South East) is out of stock of F1s in 225/35x19 and they're on back order (read five week wait) at the factory. Based on EVO's tyre test results I've looked at the Continentals, Pirellis & Michelins but they're all more expensive, and still out of stock.
    Plan B is to go for 235/35x19s in a Goodyear F1, which are in stock!
  27. N8
    17,163
    718
    So N8s Falken's it is then :Flush:
  28. maars
    576
    Haha...got offered a good deal on the 235 F1s (which I love) and reckon the extra width could look sweet! Sorry N8!
  29. Boab01
    Boab01 New Member
    15
    No question that Audi were taking the mick here but be very careful who you get your alignment done at, best get it done by someone who understands it and calibrates their kit frequently. I know a few folks round the country who do it. The wear on your tyre is almost certainly excess camber, the problem with getting this adjusted means that it will also affect your toe settings and often you have to sacrifice a little of one to gain another to keep it close to the limits of what it should be.
    Personally I'd spend the £280 and go to someone like Dixon Motorsports, Center Gravity or Wheels in Motion who'll do it properly and your car will feel amazing having had it done. There are plenty of other places but those are ones that I or pals have had positive experiences with :).
    That of course is just me, you may find that the places that charge you £50 aren't just lining up the front wheels with the back, but I'll be very surprised.
  30. maars
    576
    I don't doubt Audi would do a good job, and I'm sure it's their hourly labour fee that causes the £280 charge more than anything else. And you're right, the wear is almost certainly a result of camber change from lowering the car.
    Thanks for the recommendations. I'm in the South and was originally planning to go to Elite in Rainham, who quoted £50. I might reconsider and speak to Dixon who are not far from me...
    Wheel Alignment UK - Wheel Alignment London - 4 wheel Alignment London
  31. Boab01
    Boab01 New Member
    15
    UK Tyres Online Cheap Car Tyres Shop | Blackboots Wheels in Motion
    Or DMS will be excellent for you imo :) I've had only good reports about both.
    I do doubt Audi will do a good job ;) I've only had bad experiences with dealers on servicing with the exception of Perth Audi who are pretty good. Up here in Inverness though the local indie specialist makes the dealer look like an incompetent 4 thumbed village idiot.
  32. N8
    17,163
    718
    ^That place is super expensive^
  33. Boab01
    Boab01 New Member
    15
    £80 isn't expensive :)
  34. N8
    17,163
    718
    For 215/35/19 Falkens I was looking at almost £30 more expensive than camskill
  35. Boab01
    Boab01 New Member
    15
    Ah I was talking about alignment, sorry :). Lowering a car in that way and forgetting to get a really good geo done could be much more expensive in tyre wear :)
  36. maars
    576
    Off to get the new tyres fitted & geometry checked/fixed first thing tomorrow morning. I'll let you know how I get on!
  37. N8
    17,163
    718
    Indeed my friend, you don't need to tell me that lad :laugh:
  38. Boab01
    Boab01 New Member
    15
    Okay, now to find someone elses Granny, I think she needs to learn how to suck eggs.... Sorry :)
    I've never figured out where that came from :D
  39. N8
    17,163
    718
    Neither does my gf when I say that to her
  40. maars
    576
    New tired fitted, geometry checked & reset - normal service is resumed! I'll post more info on the setup later...
