19" to 20" Wheels question!
rajsta
2011 A6 2.0 TDI
Nottingham
I don't suppose anybody knows the details of the OE 19" split spoke wheels? Offset? Width?
Also I've been told that these same wheels come in 20" on other models!
I'm basically trying to find out if I can fit these 20" wheels to my s-line so if anybody knows the offset that these are are would also be helpful.
Not sure of spec... But I'm sure they were only available on Q7's
19" oem spec are as follows
BBS Speedlines
Offset ET43
Rim width 8.5j
Stud diameter 112
Manufacturers pt number 8K0601025S
Tyre size 255/35/19
You'll struggle with such a low offset! Mines are original S5 wheels with an offset of 33 and it rubs on the rear... Even with a little negative camber! Uploadfromtaptalk1398814457955
Uploadfromtaptalk1398814620465
Uploadfromtaptalk1398814690462
So et29 and et33 will cause rubbing if fitted to the a6!
So what would the ideal offset be for 20" wheels fitted to the a6? And maximum width without rubbing?
Someone on another forum has 8.5j ET35 with 245/35/20 on an Avant. But couldn't honestly say what would be best! Tyre choice has a big part to play as well... Some have bigger side walls as do my Bridgestones....
These are just some 19" varients ive found just to try and get an idea,
AUD*4F0601025BA1H7, 19x8.5, et48. - Audi alloy wheels | Genuine new 19" Audi 7 Double Spoke | fits Audi A6 4F Saloon/Avant | Alloy Wheels Direct Ltd
AUD 4F0601025BA8Z8, 19x8.5, et48. - Audi alloy wheels | Genuine new 19" Audi 7 Double Spoke | fits Audi A6 4F Saloon/Avant | Alloy Wheels Direct Ltd
The above two links show the same wheel (part no is Different due to colour) and the dimensions are -
19x8.5 et48. I'm assuming this is the std wheel that is fitted to the S-line!
AUD*8J0601025N1H7, 19x9, et52. - Audi alloy wheels | Genuine new 19" Audi 7 Double Spoke | fits Audi A6 4F Saloon/Avant | Alloy Wheels Direct Ltd unsure what these are fitted to.
Aly, where exactly do your wheels rub.? Inner or outer arch?
I'm just thinking if they rub on the outer arch, isnt it possible to machine the mating face down to get more clearance? Obviously without catching the caliper and inner arch!
It rubs on the outer edge! I've enquired from Arch Enemy to roll the arches but apparently there are no arches to roll on the C6... I went to a local body shop and they said the same.... :(
So with your 20" s5 wheels with et33, can you tell me if there is enough clearance between the wheel and inner arch And the brake caliper to have the wheels mating faces machined down just enough for the wheel to clear the outer arch?
