19" RS4 replicas and rubbing?
DemianM Dec 13, 2007
  1. DemianM
    DemianM RWD sucks!
    175
    I have just received (but not mounted) my 19x8.5 replicas for my S3. I am unsure whether it will rub in the back with 235/35/19 tyres. The offset is ET 48 (supposely the correct one) so can anyone with this rims confirm this??
    Thanks! :icon_thumright:
  2. S3IZZO
    S3IZZO Guest
    My fronts rub on full lock, backs are ok....I think you should be ok but I would have gone for 225's to be safe - Good luck.
  3. marriedblonde
    marriedblonde Active Member
    4,371
    What offset did you go for?
    J.
  4. DemianM
    DemianM RWD sucks!
    175
    ET 48! Should be OK for 8 inch width but mine are 8.5!
    I will mount Sumitomo HTRZII tyres, they seem narrow....if this helps!
  5. N8
    17,163
    720
    I've gone for ET 45 with a 19x8, so will I be running a 225/35/19 or 235/35/19? :think: Thanks Guys.
  6. DemianM
    DemianM RWD sucks!
    175
    I`d go with 225! I had 2 235 laying around with less than 500 kms and wanted a little bit more sidewall due to the terrible streets here.
  7. N8
    17,163
    720
    Shud I go with 225s then Ju?!
  8. mavala
    mavala Oops!!!!
    39
    It's not the width of the tyre that is causing the problem, it's the hight.
    If you go for 235, go down to 30's (235/30/19).
    This will reduce the circumference and will stop it rubbing on full lock.
    It will also make your Speedo more accurate, as you are probably going faster than what the Speedo is showing.
  9. luca1
    luca1 2 s cars soon
    14
    People with the 19's. Do they not make the handling worse? Im going to get some lightweight 18's when my car arrives.
  10. DemianM
    DemianM RWD sucks!
    175
    Do you rub in the back, or both front and back? Which tyre brand are you using?
    For the rears, you could try to remove the screw that holds the bumper to the fender, this helps a lot to reduce rubbing.
  11. -Ju-
    -Ju- Well-Known Member VCDS Map User Team Panther Audi S3
    2,416
    516
    Just the back, The tyres are Khumo's, but I have no issue with the tyres!
  12. N8
    17,163
    720
    I will go 225/35/19s then, all plastic will be getting removed from any of my arches, not having any rubbing of any kind and I'm not putting up with it, I'm getting coilovers to make my ride smoother and set it at the right ride height. I don't agree with the price of tyres the falkens I'm gettin cost the same in the 225 as with the 235.
  13. DemianM
    DemianM RWD sucks!
    175
    Some tyre brands are much more "square" on the edges. Furthermore, some tyres are WIDER! Although the nominal size might be 235, the real width is quite different among brands....
    I think I will machine the wheels a little bit (about 4mm) to gain a little more offset, this should clear the back fenders, but anyways, if the rubbing is not too much, you should look into the fenderliner, there is a screw which can be removed, or changed by a recessed head one and this will surely remove some rubbing.
    Hope this helps!
  14. N8
    17,163
    720
    Fair enough Demian, I hope mine don't rub...I will try and sort it as best as I can.
  15. DemianM
    DemianM RWD sucks!
    175
    Okey, Ill let you know how it goes, I hope I dont rub too much! :(
  16. N8
    17,163
    720
    Thanks Demian :applaus:
  17. Serberus
    Serberus Member
    I've had 19" replica RS4's on my A3 since July, the rears rub on tight corners on an incline or if I have passengers in the back. I think this is largely due to running stock springs and dampers, the car drops around 2" on the rear with a car load of people.
    I'm getting quotes now to fit Eibach Pro Kit springs and Pro dampers hoping stiffer suspension will alleviate this a little. My main concern is the offset on the front wheels which look almost flush with the wings.
    I'm on 235/35/19 Avon ZZ3's.
  18. DemianM
    DemianM RWD sucks!
    175
    Which offset and widht are you running? Do you know?
  19. Serberus
    Serberus Member
    ET42 offset and 8" width (according to the invoice).
  20. DemianM
    DemianM RWD sucks!
    175
    Your offset is quite low. Maybe you can machine a little bit of the inside of the wheels to bring the offset up a little, or you can also try removing the screws that hold the rear fenderliner to try :)
  21. Serberus
    Serberus Member
    Machining the alloys sounds like a lot of work? Where would I get that done?
    The rears will definately fit inside the arches, the front however...
    I'll post some pics at the weekend when I've got some light.
  22. SteveTDCi
    SteveTDCi Active Member
    1,407
    Has anyone looked at where the wheels are rubbing ? If its catching on the lip of the arch then they can be rolled or modified with a modifying tool also know as a hammer. I'd be concerned that they were'nt catchting on the suspension or brake components.
  23. Serberus
    Serberus Member
    I can see marks on the side of the tyre.
  24. N8
    17,163
    720
    As mentioned mine will be having the arches rolled.
  25. A3simon
    A3simon Active Member
    982
    40
    Im running 215/35/19s on my 8.5 x 19s ET45 and the car is low as it goes on kw v2 coilovers ive had no rubbing from the back and only a little from the front when cornering hard. Give them a go before having them machined as the higher offset will sit pretty far in the arches which doesnt look right
    ths is how mine looks
  26. DemianM
    DemianM RWD sucks!
    175
    Can you say............STRETCH????? :hubbahubba: I am running 235 tires on a 8,5 rim and it looks a little stretched! I cant imagine yours!!
  27. N8
    17,163
    720
    hmmmm
  28. Serberus
    Serberus Member
    Pics as promised, not sure I have the best angle on these. Tried the angle DemianM used but didn't work for me. The fronts are what I'm worried about.
    There's more space on the rear arches and they already clear (and rub inside the arch).
    The car does ride pretty high atm, I can't see a drop of 25mm causing too many problems - drove to Birmingham yesterday (~170 miles) no rubbing with me and 1 passenger in the front.
  29. DemianM
    DemianM RWD sucks!
    175
    I think you will rub even more lowered.....eibach pro kits usually are quite soft.
    Did you remove the screw that holds the fenderliner to the bumper?
  30. Serberus
    Serberus Member
    Nope, not removed that screw.
    The pro kit will be stiffer than the OEM springs and dampers though?
  31. DemianM
    DemianM RWD sucks!
    175
    Not that much.....Even worse, they are progressive so the car will be lower and SOFTER for one part of the spring, and then it will get stiffer as you go further low on bumps.
    Why dont you remove the screws first and try?
  32. Serberus
    Serberus Member
    I'll give it a go. Will removing these screws cause any other issues? Will the fenderliner vibrate while driving if I remove these?
  33. Nath-340R
    Nath-340R New Member
    26
    Please can some one tell me how much the Audi RS4 wheels are compared to Reps? Just out of interest.
    sorry to go off subject a bit
    thanks
  34. dipstic
    dipstic Member
    384
    I asked today about genuine Audi RS4 style to fit my S3
    18X8JX ET 54 = £254+ VAT Each (same size as my S3 ones)
    Most Reps seem to be either 45/42 et depending on who is measuring them.
    Cheapest I have seen is £250 for four without tyres (18") no idea of the quality though
    Can understand people having rubbing issues with reps as they are already 9mm nearer the bodywork without taking tyre size into consideration
  35. Nath-340R
    26
    Thanks for that. If I was going to do it, I would go for the 19" I think, Any idea how much they are off Audi?
    Nath
  36. Serberus
    Serberus Member
    Did you do this in the end?
  37. DemianM
    DemianM RWD sucks!
    175
    No, my RS4 wheels are the replicas which have the most "curve", the spokes have a lot of curvature from the lip towards the center so the remaining material in the place where the bolts seat is not a lot, so I wouldnt be confortable riding on them with so little material left.....:no:
    On the other hand, that was going to be my cure in case of serious rubbing but fortunately, I havent rubbed except while "jumping" a speedbump (something not so healty) but on otherwise realworld crusing the car does not rub at all (at least with 2 persons on board). I never carry passengers so I guess I am OK.
  38. maars
    maars Full speed ahead
    576
    Some of the US guys on the vwvortex forum run 225/35x19 on 19x8.5et48 massively lowered and don't have any rubbing issues...so you should be fine.
