19" Audi Alloys on an A3
loveland Sep 17, 2012
  1. loveland
    loveland New Member
    Hi was just wondering if 19" Audi RS4 alloys will fit my A3 sportback?
    Or do they need some adjustment?
    thanks
    Will
  2. MartayMcFly
    MartayMcFly Booooooost VCDS Map User Gold Supporter
    2,766
    355
    Genuine RS4 ones won't fit, too wide and ET too low.
  3. Ash187
    7,520
    757
    get the specs of the alloys up and we can advise... also if you havnt already you will want to drop the car a bit otherwise it will look like a range rover :jester:
  4. loveland
    loveland New Member
    I have been told the stud pattern is 5x112, which is fine. But the offset is ET45? Will that be okay or is it too much?
  5. MartayMcFly
    2,766
    355
    8.5" wide or narrower on ET45 will fit.
  6. N8
    17,163
    720
    9J ET45 will fit as well Mart ;)
    MartayMcFly likes this.
  7. loveland
    loveland New Member
    Ah Okay the tyres are 235/35ZR19 91W? Sorry Complete newbie to alloys! haha
  8. MartayMcFly
    2,766
    355
    235mm wide tyres, 35% profile side-walls, forget what the Z means, inner radius 19", 91 is the load rating (615kg) and finally W is for speed rating (168mph max).
    You'd be better off with 225/35s, or 215 even on a 9" wide rim.
    Side note: N8, what's the lowest ET on a 9 that'll fit?
  9. audicruiser
    audicruiser Audi Heaven
    1,865
    Considering the RS4 had bespoke arches I would of thought would give the answer...
  10. MartayMcFly
    2,766
    355
    Fair point, but the hubs aren't the same, and neither is the suspension so the arches are only worth considering versus a standard A4 (which probably has different hubs too).
  11. loveland
    loveland New Member
    So Just to confirm they will fit but, 225/35s, or 215 would be better?
  12. N8
    17,163
    720
    Depends brother ;)
