19" 8j wheels all round - what size spacers?
Nogmeister Nov 23, 2012
  1. Nogmeister
    Nogmeister Member
    287
    As above, what size spacers can i get away with front and rear?
  2. jojo
    28,881
    3,532
    10mm front 15-20mm rear, based on using 235/35R19s
  3. olethalb
    olethalb Active Member
    357
    76
    completely depends on what offset the wheel is
    (if there is a pic i apologise i don't get access to pics at work)
  4. jojo
    28,881
    3,532
    Of course this information is correct, my reply was based on wheels with ET35 offset, basically, the range is ET25-35 on the fronts and ET 20-35 rear, you could probably run 20mm's on the rears, I'm pretty sure that will clear.
  5. Sam_
    Sam_ Down under
    3,038
    480
    I run ET5 rear on 8.5s, if it wasn't for that stupid little plastic "block" on the outside arch liner, it'd be fine. Rubs ever so slightly now and then...
  6. ci-ryder
    ci-ryder Member
    199
    ET53 Alloys, 19x9's, 35mm spacers front, 45mm spacers rear and fits fine. What wheels are you looking to put on?
  7. jojo
    28,881
    3,532
    Making them ET8, must be some rather long bolts you are using though...
  8. ci-ryder
    ci-ryder Member
    199
    Yep they are, sadly I need to find one longer one as I damaged part of the thread on one of the adapters :banghead:
