19´´ BBS from A6 4F
Discussion in 'A3/S3/Sportback (8P Chassis)' started by shaheed, Apr 17, 2007.
  1. shaheed
    shaheed Member
    Dec 30, 2004
    65
    Hi there,
    From long time ago I'm trying to understand if I would be able to put some 19'', 8,5'' ET48 BBS wheels 2 parts from A6 4F model in my 8P model.
    Basically what makes doubts to me are the 8.5´´, one inch more than standard, and also how the 225 tires would fit in a wheel which usually uses 255.... Would the wheels have a clearance distance to the inside of arches?
    Any experiences, any tips?
    Regards.
  2. Advert Guest Advertisement
  3. Boydie
    Boydie Guest
    are they 5x112?
    8.5" should fit but if you were seriously lowering your car it MIGHT scobe but i think you should be ok!
  4. marriedblonde
    marriedblonde Active Member
    Dec 6, 2004
    4,371
    225 tyres on an 8.5" wide rim wont be a problem at all.
    If they have a pcd of 5x112 then they should fit without any issues. an offset of 48mm will be perfect for a lowered car as well :)
  5. shaheed
    shaheed Member
    Dec 30, 2004
    65
  6. shaheed
    shaheed Member
    Dec 30, 2004
    65
    I was doing calculations....
    and....
    8.5´´ offset 48 VS 8'' offset 42 (like yours married)
    and results are...
    Both would fit exactly the same having the outer part as a reference. Meaning the wheel would be really on the same line as the arch, correct married?
    Basically I don't like to see wheels getting too much out if the car is not lowered....like yours before getting Sportline.
    Can you please send me photos just from the front of the car, to see how the wheel would sit in the front arch? I do think in the back there's no problems.
  7. marriedblonde
    Dec 6, 2004
    4,371
    The rear is going to be where the rubbing occurs!
    a 225 tyre on a 8.5" rim wil not be an issue! I had 8.5" rims on my R32 without any problems running a 225/40/18 tyre.
    I'll have a look for some pics.
    J.
