18x8 -et44 will fit an s3 sportback with coilovers
Paul_S3 Jan 7, 2012
  1. Paul_S3
    Paul_S3 Member
    114
    22
    I can get a set of bbs ch wheels which i will use during winter times. They ome from a vw gti 30th ed but the et44 worries me a bit.
    Will they fit because my speedlines are et48 and just fit but the ch's are 8.5j but i am not sure that makes a difference.
    So will et44 fit with 8j
  2. Paul_S3
    Paul_S3 Member
    114
    22
    Nobody knows? Not even n8 ;)
  3. N8
    17,163
    718
    Why didn't you just send a pm? What size tyres are you planning to run? I'm running 18x8 ET45 currently with a 225/40/18, can still run it quite low, but I'm on air, you'd have to play around with ride height.
  4. Paul_S3
    Paul_S3 Member
    114
    22
    I will run 225/40/18 tires and i am around 4 cm down in kw coilovers.
    On what height can you still drive it? Any rubbing?
    I didn't pm because i hoped on quite some answers
  5. warren_S5
    warren_S5 Moderator Moderator VCDS Map User
    7,210
    2,487
  6. N8
    17,163
    718
    I'm on air ride, so I run off PSI. You'll have to just see how it goes, either lower/raise.
  7. Synchromesh
    Synchromesh :-)
    98
    I've been running 8x18 ET43 with 225/40 18 and Bilstein PSS B14 coilovers (not very low though) for some time now and I have no problems... you'll be fine :)
  8. Paul_S3
    Paul_S3 Member
    114
    22
    ThaNks for the reply. Even fully packed no rubbing with et33, or people in the back?
