17545 - Fuel Trim: Bank 1: System too Rich
Westy Feb 25, 2011
  1. Westy
    Westy Well-Known Member
    17,443
    1,105
    The following error has come up on my mates car which is an A3 1.8T Sport (AUM). Audi have told him that the car needs a new cat but I have been doing some tests on it and I believe the fault is with something else.
    1 Fault Found:
    17545 - Fuel Trim: Bank 1 (Add): System too Rich
    P1137 - 35-00 - -
    Firstly can anyone confirm what the power output of the AUM K03s should be as the MAF is calculating around 150bhp
    Secondly has anyone had this error before, and can you shed any light on the problem?
    I've tested the lambda sensors and the fuel EVAP system and everything comes back fine. I cleared the MIL and the car seems to drive fine, very smooth and no hesitation to suggest the Cat is shagged! My mate says that the car just seems to cut its power which I think is due to the MIL putting the car into limp mode.
    Anyway this is what Ross-Tech suggest may be the problem so I will check:
    17545/P1137/004407 - Fuel Trim: Bank 1 (Add): System too Rich
    Possible Symptoms
    • Malfunction Indicator Light (MIL) active
    Possible Causes
    • Mass Air Flow (MAF) Sensor faulty
    • Fuel Pressure Regulator faulty
    • Fuel Injector(s) faulty
    • Oxygen Sensor Control faulty
      • Oxygen Sensor(s) faulty
    • Evaporative Emission (EVAP) System faulty
    Possible Solutions
    • Check Mass Air Flow (MAF) Sensor
    • Check Fuel Pressure Regulator
    • Check Fuel Injector(s)
    • Check Oxygen Sensor Control
      • Check Oxygen Sensor(s)
    • Check Evaporative Emission (EVAP) System
    Thanks for any help.
    Westy
  2. [Dave B]
    [Dave B] Daddy
    2,027
    145
    I had a very similar fault as detailed in this thread: http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/109628-mafs-boost-leaks-info-please.html
    This was eventually discovered to be a clogged FPR due to vPower dissolving the insides of the rubber fuel pipes leading to the fuel rail, as pictured in my thread about Badger5 TIP and JC Filter.
    Your code is slightly different though as it states (Add) rather than (Multi). There's a good explanation about the differences somewhere.....
  3. badger5
    9,543
    2,022
    this
  4. [Dave B]
    [Dave B] Daddy
    2,027
    145
    That's the bad boy..
  5. [Dave B]
    [Dave B] Daddy
    2,027
    145
  6. Westy
    17,443
    1,105
  7. Westy
    17,443
    1,105
    Right, it's definitely not the FPR as I just checked it in the work carpark. It's clean as a whistle.
    Word of warning, dont do mechanical work in a suit! The FPR still had pressure in it and I got sprayed with fuel as I popped the top off. My colleagues in the office aren't best pleased with the smell!
  8. Carl.S
    Carl.S Member
    194
    boost leak is also a possibility
  9. DenCar
    DenCar Member
    404
    I had that code along with the code for a problem with the pre-cat lambada sensor, i had a new lambada fitted and and the code has not returned. Fuel economy improved from around 26mpg to 35 mpg now. This was on my wifes car.
    DC
  10. westcoast a3
    westcoast a3 Active Member
    319
    37
    @Westy did you get to the bottom of this code ?? having same issue both lambdas new, fpr new going to check out a possible boost leak tomorrow and change a possible leaking injector. cheers
  11. superkarl
    superkarl MAN OF STEEL
    9,554
    2,453
    Don't rule out the most temperamental sensor of them all, MAF
    westcoast a3 likes this.
  12. Westy
    17,443
    1,105
    No, never got to the bottom of this but to be honest I never had a good look at it as it was for a guy at my old work place. He ended up selling it as it was at the time.
  13. badger5
    9,543
    2,022
    logs?
    block 001,002,031, and report what block 032 says
    What car? engine code?
  14. westcoast a3
    319
    37
    @badger5 it's an a3 1.8tqs with apy s3 engine, in it though.
    You haven't as yet done any logs as my mate has now borrowed my cable, though today I took the injectors out and all the rings in the rail had swollen, I have changed them for now car feels better but won't get a chance to log till Saturday,.
    @superkarl
    The maf is also new genuine Bosch.
    Thanks guys :)
  15. badger5
    9,543
    2,022
    narrow band ecu then yes or wideband?
  16. westcoast a3
    319
    37
    It is wide band, with vvt tensioner, swapped out my ary for apy as was rodded, car is 2001
  17. badger5
    9,543
    2,022
    vcds to check fuel trims on 032 and maf reading on 002, and lambda adjustment on 001
  18. badger5
    9,543
    2,022
    we have seen this once where customer had fitted their in tank pump and kinked the return fuel line... Too much fuel pressure consequently
  19. westcoast a3
    319
    37
    @badger5 I will go and get these done asap, and report back, also a noob question do you do these logs with car running ? Thanks :)
    Mav190sline likes this.
  20. badger5
    9,543
    2,022
    block 032 just read the number. Dont reset faultcodes as this will zero the adaptions.
    the other blocks need to be live data yes
  21. westcoast a3
    319
    37
  22. westcoast a3
    319
    37
    @badger5 I have finally done some logs :) [​IMG]
  23. westcoast a3
    319
    37
    Unsure how to post, the file is in excel, only lets me pick certain file types and that isn't one lol
  24. westcoast a3
    319
    37
    Sorry the best I can do till I work out how to post the full file lol :) thanks again :)
  25. badger5
    9,543
    2,022
    you stuck a 4bar fpr on there?
  26. westcoast a3
    319
    37
    I bought a new fpr topran thought was a 3bar as phoned company selling, told me it was. I have since changed it to a genuine 3bar when this log was taken, also changed the injectors, and checked for boost leaks
  27. westcoast a3
    319
    37
    Although since doing the fpr and injectors the 17545 code hasn't come back :/
