Nick Clarke
- Joined
- Feb 20, 2015
- Messages
- 37
- Reaction score
- 3
- Points
- 8
Hi guys, I have a a3 1.8t aum which has a 3" decat and milltek full system. It was remapped before the exhaust was fitted at AMD in Essex. I have also just done the well advised n249/112 delete.
The sai pump is still in place and is noisy, but on inspection someone has bolted it together in the past, but I do have a split in the pipe that comes out of the pump. I have 2 engine related fault codes, 1 which I have had since owning the car in Feb, sai incorrect flow, and fuel trim to lean on bank 1 which has just popped up 3 days after doing the n249 delete, which I presume has caused the eml light to come on.
So.... my question is, what is the most likely cause of the fuel trim code? Decat (which was done 3 weeks ago) or no vacuum feed to combi valve for sai? Do I need to still provide vacuum to this from somewhere else I.e fpr? Or does the lamda sensor need a spacer?
Thanks for any suggestions that may come!
