17090/f125/p0706/codes need urgent help
martyn brooks Sep 5, 2010
  1. martyn brooks
    martyn brooks New Member
    22
    i have a audi a6 2004 130 tdi sport with a multronic g/box .ghq with130.000mls. prnds lights have started flashing on dashdisplay..i got it hooked up on a snapon diagnostics and the following came up to which i need help..........17090 transmition range sensor f125 implausable signal p0706 intermitant 4b0910155cv30-01j1.9Ltd rwd3120 coding0000001wfc004926 ......enginne is avf..g/box is ghQ chassis no wauzzz4b94no84760 if this helps with any answers
  2. NHN
    29,343
    1,719
    Check if there is a sensor within the transmission that can be replaced mate, your local dealer should be able to advise a little of this just in parts.
  3. tariqonnet
    tariqonnet tariqonnet
    Hi, did you resolve you problem? I'm currently facing same problem. Can you share your experience or any suggestions
    Tariq
  4. martyn brooks
    22
    hi i had to have gearbox ecu repaired///gearbox rear removed .ecu sent for refurb .new oil refited and reset with vagcom.....£800 what a bummer ..local garage would have done removal of ecu of which i would have to sort out refurb £250+vat] they would put back/ add new oil ect/ect £250+vat but no guarantee //so opted to go to carvers in denton manchester ..2year warenty £800 ...touch wood all ok now ..carvers also showed me damaged sensor on ecu [cracked] of which was replaced with new when refurbed..ps there is a few companys that refurb..just google g/box ecu repairs.indetech are suposed to be best but are in miltonkeens ...good luck hope it doesnt hurt to the tune of 800
