17075 - Fan 1 Control Circuit: Short to GND
RGC Feb 22, 2009
  1. RGC
    RGC Keep on rollin
    150
    Hi today i turned on my Air con for its monthly run and lo and behold i have got the dreaded ECON light not turning off,
    i have looked through the forum and cant find the same 3 faults together,
    i have checked the fuses and all are fine this time,
    i say this time because a few month ago i had the 10amp fuse blow which supply's the fans and the Motor Intake Manifold Flap, this brought on the check engine light with it also, replaced the fuse and all was fine
    so i am stuck,
    is the problem the fans of the intake flap?
    trust them to be on the same circuit eh
    there is nothing obstructing the fans so that cant be the fault, are the fans a common failing part?
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 AT HW: 028 101 145 3
    Component: R4 2,0L EDC 0000AG 5689
    Revision: 12345678 Serial number: AUX7Z0CNFNS00M
    Coding: 0000078
    Shop #: WSC 06435 000 00000
    3 Faults Found:
    18359 - Radiator Fan 2 (V177): Movement Restricted / Jammed
    P1951 - 000 - - - Intermittent
    Freeze Frame:
    RPM: 798 /min
    Torque: 34.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 13.98 V
    Bin. Bits: 11000100
    Temperature: 86.4°C
    Duty Cycle: 25.1 %
    18358 - Radiator Fan (V7): Movement Restricted / Jammed
    P1950 - 000 - - - Intermittent
    Freeze Frame:
    RPM: 798 /min
    Torque: 30.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.21 V
    Bin. Bits: 11000100
    Temperature: 85.5°C
    Duty Cycle: 9.6 %
    P0691 - 000 - - - Intermittent
    Freeze Frame:
    RPM: 819 /min
    Torque: 18.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.14 V
    Bin. Bits: 11000100
    Temperature: 87.3°C
    Duty Cycle: 9.6 %
    Readiness: 0 0 0 0 0
  2. kaz219
    kaz219 Active Member
    1,808
    The IMF and fan are on the same fuse but If the IMF blows the F8 fuse, you get these codes
    3 Faults Found:
    19558 - Motor for Intake Manifold Flap (V157): No Signal
    P3102 - 000 - - - Intermittent
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.46 V
    Bin. Bits: 00101100
    Torque: 0.0 Nm
    Torque: 92.0 Nm
    19557 - Motor for Intake Manifold Flap (V157): Open or Short to Ground
    P3101 - 000 - -
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.46 V
    Bin. Bits: 00101100
    Torque: 0.0 Nm
    Torque: 92.0 Nm
    P0691 - 000 - -
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.46 V
    Bin. Bits: 00101100
    Temperature: 90.0°C
    Duty Cycle: 9.6 %
    Thats a probs with the fans which is causing the F8 fuse to blow...
  3. kaz219
    1,808
    Here's more help on the fault code
    18359/P1951/006481 - Radiator Fan 2 (V177): Movement Restricted / Jammed
    Possible Causes
    • Coolant Fan 2 (V177) restricted/jammed
    Possible Solutions
    • Check Coolant Fan 2 (V177) for Restriction/Blockade
      • Check for Foreign Objects and Accidental Damage as well as Restrictions
    Special Notes
    • Remove the Coolant Fan 2 (V177) Fuse(s) for Safety Reasons before checking it
    So make sure there's nothing blocking the fan....again!
    On an old car, there was a screw stuck in the fan which a mechanic had dropped in the fan which restricted it from spining when it got wedged...it got wedged every now and then so keep spining the fan and see it it does jam...
    Or, clear codes, start up the car, warm it up to 90 and then park up and rev it to 2kish and hold (get a friend to do it) and wait for fans to kick it... Watch them to make sure thye dont jam and if they dont and the fault code appears - it may be sensor
    Is it under warranty??
    EDITED!!!
  4. RGC
    RGC Keep on rollin
    150
    hi yes it seems to be the fans at fault this time and must have been my IMF b4,
    note: the fuse did not blow this time just logged the faults.
    they move freely and are OK,
    which sensor could be at fault?
    not under warranty unfortunately
    Richy
  5. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,508
    647
    Easy fix - buy a new throttle body from eurocarparts - £175
    Not hard to fit either
    Fit it, vagcom it, clear codes - job done!!
  6. RGC
    RGC Keep on rollin
    150
    Hi Boydie thanks for the input but its not actuality the throttle body that i am having the problem with its my ECON light staying on after the fans trip
    3 Faults Found:
    Freeze Frame:
    RPM: 798 /min
    Torque: 34.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 13.98 V
    Bin. Bits: 11000100
    Temperature: 86.4°C
    Duty Cycle: 25.1 %
    Freeze Frame:
    RPM: 798 /min
    Torque: 30.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.21 V
    Bin. Bits: 11000100
    Temperature: 85.5°C
    Duty Cycle: 9.6 %
    Freeze Frame:
    RPM: 819 /min
    Torque: 18.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.14 V
    Bin. Bits: 11000100
    Temperature: 87.3°C
    Duty Cycle: 9.6 %
  7. kaz219
    1,808
    If you are sure the fans didnt trip when the car was revved a 2.5k and heated up proper than it could be loose connection that moves - check them.
    If not, im not really too sure what it could be but at a guess, it could be the fan motor itself sending out errors as it thinks its jammed..
    TBH, dont know too much on the fans but the golfs had a common prob with a control box or something blowing...
    BEst of waiting along to see is anyone has soem know how on the issue on here and if not, take it to a garage..
  8. dkingy11
    dkingy11 Member
    69
    Im having similar problem. ECON light came on few weeks ago and turned out air con was leaking! Had air con pipe replaced but still no luck so getting condensor replaced soon and hopefully that will sort it
  9. RGC
    RGC Keep on rollin
    150
    any errors loged in vag com ?
