17069 - ECM Power Relay Control Circuit
jesters3 Dec 13, 2007
  1. jesters3
    jesters3 Active Member VCDS Map User
    1,516
    Arvo,
    just ran a quick check and got the following back
    Thursday, 13 December 2007, 10:58:00
    VAG-COM Version: Release 409.1-S
    Control Module Part Number: 8N0 906 018 BH
    Component and/or Version: 1.8L R4/5VT 0001
    Software Coding: 10710
    Work Shop Code: WSC 13365
    Additional Info: WAUZZZ8L721017033 AUZ7Z0A2027901
    9 Faults Found:
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 35-10 - - - Intermittent
    17069 - ECM Power Relay Control Circuit (J271): Open
    P0685 - 35-10 - - - Intermittent
    16622 - Manifold Pressure / Boost Sensor (G31): Signal too High
    P0238 - 35-10 - - - Intermittent
    18057 - Powertrain Data Bus: Missing Message from ABS Controller
    P1649 - 35-10 - - - Intermittent
    18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
    P1650 - 35-10 - - - Intermittent
    16497 - Intake Air Temp. Sensor (G42): Signal too High
    P0113 - 35-10 - - - Intermittent
    16502 - Engine Coolant Temp. Sensor (G62): Signal too High
    P0118 - 35-10 - - - Intermittent
    17931 - Crash Signal from Airbag Controller: Implausible Signal
    P1523 - 35-10 - - - Intermittent
    17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
    P1297 - 35-10 - - - Intermittent
    I have cleared them and about to go out for a drive then rescan. I'm pretty much happy with most of them but I can't find this one:
    Have checked the Ross bible and googled but nothing; Any ideas?
