170 TDI chrome exhaust tip
AudiLad Feb 18, 2008
  1. Bailey
    Bailey Member
    247
    15
    i am thinking of doing this to my audi! are there any out there on ebay? i have only seen cheap tacky tips at the moment on there.
  2. matayas
    matayas New Member
    12
    when removing the old tips , was it nessesery to remove the exhaust from the car ?
    and what cutting tool did you find best to use ??
    i have the shiney tips just need to remove the old ones
  3. johal87
    johal87 Member
    331
    Has anybody got a updated link on these?
  4. matayas
    matayas New Member
    12
    tips or advise on tools to use to remove the old welded on exhaust tips ? any body?
  5. RS84
    RS84 R15 - TDI Power
    168
    I used a Dremel when I did it. But if I had to do it again I'd get an angle grinder at it.
    Just be careful that you only cut into the steel outer tip and the weld and not the actual exhaust pipe.
  6. Paul_c
    Paul_c Member
    139
    :iagree: I used an angle grinder... It's a bit tricky but just take your time and you'll be right!.
  7. matayas
    matayas New Member
    12
    Cheers guys
    did you remove the back box ? or is it safe to do it on the car ?
    weather permitting am gonna have a crack at it this weekend
  8. RS84
    168
    I suppose in an ideal world if you had access to a grease pit you could get under the car with a lamp and the job would take all of 10 mins.
    I reversed the back wheels onto a pair of big patio slabs when I did it to make getting under the exhaust a bit easier.
    No need to remove anything from the car to do it...
  9. latta1989
    latta1989 Member
    147
  10. Mindak
    Mindak Active Member
    797
    130
    43
    Old thread revival here! lol
    Went to my local powerflow dealer and they showed me the tips they had available and thought the 75mm angled were the best and they'll cut and weld them for £80 that sound reasonable?
  11. SmithyAG
    SmithyAG Active Member
    414
    61
    I'm considering doing this too lol.
    Theres a powerflow place near me and if it's £80 for the old tips cut off and the new ones welded on, then that's what I will be doing, as opposed to using tips held on by grub screws.
  12. Mindak
    797
    130
    43
    Yea I didn't fancy tacky ones, they had so much choice but obviously wanted original looking ones, when the tips are in they will be calling me so il let you know how I get on!
  13. SmithyAG
    414
    61
    Thanks mate, would be good to see how it looks.
  14. Mindak
    797
    130
    43
    Update time... Just got bk from my local powerflow for my tips fitting and in very happy!
    Got them to cut the tips off aswell as some of the pipes underneath so can't be seen inside the new tips!
    Before
    After
    Well chuffed with the result and well worth every penny!
    What do you guys think?
  15. Jackx1
    Jackx1 Member
    126
    15
    I did exactly the same mindak! The guys at powerflow were amazing! Looks 100% better
  16. SmithyAG
    414
    61
    Both look fantastic. A great improvement.
    I know where my next stop will be!
