17 psi with s3, is it too much?
s3withproblems Nov 23, 2004
  1. s3withproblems
    s3withproblems New Member
    21
    Some said that over 15 psi is dangerous for an s3, that much pressure breaks the pistons. After chipping mine boosts 17 psi, Am I in danger ? (it doesnt go to limp mode)
  2. RichA3Turbo
    RichA3Turbo ...Watching you! Moderator
    5,089
    [ QUOTE ]
    [/ QUOTE ]
    17psi is about 1.2 bar... THis aint going to break anything! S3 can handle about 1.7/1.8 reasonably safely althogh i wouldnt want to for any period of time
    Rich
  3. s3withproblems
    21
    Why wouldnt you want to , isnt more boost more hp ?
    Also the same one said that even subaru breaks pistons over 15 psi , more comments ?
  4. dickys3
    2,963
    23
    [ QUOTE ]
    [/ QUOTE ]
    you may get more power but the turbo will be stressed and it will only be a matter of time before it goes.
  5. S3JUS
    S3JUS New Member
    22
    the standard revo map runs 17psi which is (low boost 9)
    i have this setting on mine and does not seem to be stressing too much.
  6. NWMark
    NWMark Member
    211
    14
    my revo map (98 ron using sps2) boosts to 1.45 bar then slowly drops to around 1.05 bar at 6400rpm
    i believe 1.45 bar is about 19psi.
    Mark
  7. StevieBogan
    StevieBogan Member
    144
    Up, this is the same as mine Mark.
    Can, the Jap stuff does tend to run less boost the the VAG engined cars for some reason.
  8. RichA3Turbo
    5,089
    [ QUOTE ]
    [/ QUOTE ]
    No... More boost is more torque, not HP. You can increase the boost and make a big difference in torque while barely changing the HP figure.
    Rich
