140's, 170's, DPF
MarkRobinson Jul 21, 2010
  1. MarkRobinson
    MarkRobinson New Member
    Hi all, first post so excuse the newbness. I'm looking to buy an A3 2.0TDI Sport or S-line, probably around 3-5 years old. I originally wanted the 170 but all these problems with the DPF are concerning me. My question is will the 140's be fitted with DPF and how can I tell whether or not they have this feature? Also are any 170's DPF free?
    Mark
  2. s3 Hoggy
    s3 Hoggy Whats going on???
    1,716
    158
    Hello pal welcome to the forum,
    Your in the wrong section you want the 8p (new a3) section
  3. mk1chopper
    mk1chopper Missing the S3
    1,092
    Hi and welcome to asn, as mentioned your in the wrong section but I now want to know what a DPF is
  4. S3 TAM
    S3 TAM Pocket now empty
    624
    10
  5. shanejess
    shanejess Guest
    the 170 is what you want, the 140 is pd, the 170 is common rail remove the dpf on the 170 and downpipe 225bhp and over 370lb f,t i have the 170 black edition which has been remaped by giac as well as the dpf work to get the figures.
  6. MintyS3
    MintyS3 Works 60% the time, Everytime.
    1,580
    Although you will no doubt get better mpg on the 140 :)
  7. jojo
    28,856
    3,516
    You can get the 140 is common rail also, just depends on what year the car is.
  8. Indie_DSG
    Indie_DSG Member
    99
    All correct answers.
    I have a PD170 and only last week had to change a common fault with the DPF sensor, only £90 fix.
    DPF's were put on Diesels around 2006, an easy way to tell is to look at the tail pipes, if they bend down at the tip toward the ground = NO DPF, if the tail pipe is straight you can assume the car has a DPF.
    Most new late 2008 & 2009 TDI will probably be Common Rail (CR140 - CR170)
    The DPF only really cloggs if your not doing many miles, so if you plan to use on short day journeys DONT BOTHER!
    UNLESS..........
    You want to have the DPF removed and a full replacement exhaust system fitted? Miltek seems to be the most popular choice but also be ready for the hefty price as not only will you need a full system you will need the car re-mapped to get around the lack of a DPF and the sensor alarms etc..
    I too was worried but touch wood! Not had any majour problems but then again I do have an hour journey to and from work every day!
    One last thing GO DSG!
  9. smudge_don
    smudge_don Active Member
    2,944
    I've had both the PD140 and now the PD170
    The 170 is much nicer to drive, and of course a fair bit quicker!!!
    There aren't really any PROBLEMS as such with the DPF, apart from it gets clogged every now and then if you do a lot of around town driving. But a quick motorway dash gets rid of that!
    I'm soon to get a new exhaust system anyway, as if you want to map the PD170, you need to get a DPF delete pipe to get anything over 200bhp
