140 or 170 clutch - which is best? - part numbers?
Discussion in 'A3/S3/Sportback (8P Chassis)' started by munchkincoupe, Nov 24, 2011.
  1. munchkincoupe
    munchkincoupe Member
    Aug 21, 2010
    952
    19
    Interested in doing the clutch on my car as just had remap and figure it will only be a matter of time before the clutch needs doing so wanted to keep a look out for parts now. It's a 3dr 2004 2.0 tdi manual gearbox on 52k miles and remap to approx 170bhp.
    If anyone knows the exact parts needed (presume clutch and DMF) and their part numbers that would be great
    Also is the clutch on the 170bhp 2.0 tdi a direct fit and is it a better clutch to fit
    Do any other model in the A3 range share the same clutch?
    Thanks for any help
  2. Advert Guest Advertisement
  3. c_w
    c_w Well-Known Member
    Feb 23, 2010
    1,163
    87
    AFAIK the clutch on the 170 is the same as the 140. However on all models there is a confusion on what type of clutch/flywheel is fitted either Luk or Sachs and can only be known when the gearbox is off. Apparently they must be replaced like with like but I don't understand if you are changing for example the flywheel and the clutch that you can't just use either.
  4. munchkincoupe
    Aug 21, 2010
    952
    19
    I've got a full Sachs clutch on the way but as I've only had one slight clutch slip yesterday I think the flywheel should be ok - fingers crossed I've not got the LUK fitted?!?
  5. munchkincoupe
    Aug 21, 2010
    952
    19
  6. tdi-man
    tdi-man Well-Known Member
    Jul 27, 2009
    1,798
    64
    DONT NOT BUY CLUTCH FROM THESE PEOPLE TECHNICLUTCH READ THERE FEEDBACK ALSO SEARCH THE INTERNET ON THE COMPANY NAME AND YOU WILL FIND BAD REPORTS .
  7. munchkincoupe
    Aug 21, 2010
    952
    19
    Thanks - did search after posting it up - why doesn't Ebay get rid of them?!?
  8. Jord
    Jord Member
    Dec 8, 2010
    280
    I'd be interested to see prices of clutches, I've had mine remapped and I've got slight clutch slip
    Audi want £500 for clutch n dmf
