12volt socket power source / Cigarette lighter not working
mister.c. Jan 23, 2008
  1. mister.c.
    mister.c. Active Member TeamMisano Audi A3
    676
    131
    43
    Well first of all, I raise my hands and say I am not the most knowledgeable about how cars work :confused: (gets my excuses in first but oil and screenwash is about my level) so I'm a little stumped with this problem - any thoughts / help gratefully received before I call in the professionals (who will no doubt laugh at me!)
    I have the non smoking pack in a 55 2.0 tdi A3 sport - 12 volt socket by the handbrake. I rarely use it apart from occasionally charging my phone. But when I came to use it a few days ago it didn't work. First check was nothing had fallen in there - there was a 5p in there (which I removed) & then tried to work the phone charger - nothing working; I wonder if this could have led to something going wrong..
    So today I tried my new Halfords digital tyre inflator which is supposed to work off the 12v - again no hint of power.
    I thought it could be fuse related so found the fuse box (on the left hand side of engine compartment). Looking at p342 of my manual which covers fuses and diesels, I vainly hunted for a fuse that said 'Cigarette Lighter' but I've not seen one so got stumped at this point. I looked at F1 (Convenience Electronics) but that fuse was ok (I looked and changed this one). P340 mentions (for those cars with the box at left hand panel of dash) that the lighter is a 20 amps fuse & F1 is the only 20amp in the fuse box.
    At this stage I've admitted temporary defeat, sidetracked with having to now go and sort out a new tyre due to a nail & tyre with 5psi - aah the joys of cars!
    Again, any thoughts, areas to look at etc greatfully received, and thanks offered in advance.
    :thumbsup:
  2. h5djr
    9,465
    1,772
    The fuse covering the 12v socket (Cigarette lighter) is not in the fusebox in the engine compartment. According to my Sportback (2007) manual you need to replace fuse in the fusebox located at the driver's end of the dashboard. Just pull off the cover and replace fuse 24 with a new 20amp fuse. Hopefully that will cure the problem.
  3. mister.c.
    676
    131
    43
    Thanks David for plugging my non existant knowledge! Reading the manual I had pulled off the side panel on the passengers side dash fascia; when not finding any fuses I'd wrongly assumed that some cars had them there and some had them in the engine bay!
    Shhh - Dont laugh peeps!
    Fuse 24 now changed and 12v lighter back in action.
    Thanks again
    MrLapou likes this.
  4. Tomwebb
    Tomwebb A3 2.0 tdi s line 170
    60
    i think i need to try this tomorrow! :(
  5. Ruislip_Gooner
    Ruislip_Gooner New Member
    Hi Tom, did this work ?
    My cigarette lighter is on needed for charging my phone, and I'm getting no power. The red illumination is on, so I'm not sure if the fuse will cure the problem, but just thought I'd ask.
  6. T8DPR
    T8DPR If Carlsberg Made Audi Drivers...
    849
    153
    43
    here's another one, my fuse blew a few weeks back, it had been fine in the 15 months I've had it, I'd used it mostly for running an in-car video camera and occasionally for phone charging
    replaced the fuse but it blew immediately when I plugged the dash cam in again
  7. fangio
    fangio Well-Known Member
    1,541
    187
    Short in dash-cam lead? Try plugging the lead in on its own.
    If that's OK, it'll be the dash-cam....
