110k miles s3 fidgity ride
kek700 Mar 7, 2010
  1. kek700
    kek700 New Member
    13
    Fidgety ride, will not track straight, fidgets about when travelling in a straight line.
    I wonder if anyone can help, it could be, bushes, worn dampers, tracking, castor,
    Or ???
    I have checked camber (– 1 degree each side).
    It is also very sensitive to front tyre pressures, requiring them to be exactly the same on both fronts.
    Is there a reason that I can investigate that normally occurs at this mileage?
  2. MartayMcFly
    MartayMcFly Booooooost VCDS Map User Gold Supporter
    2,760
    354
    I'd guess ARBs and/or bushes. Had the same thing going on with mine, bushes were completely gone.
  3. kek700
    kek700 New Member
    13
    thanks for the reply, probably get myself a front poly bush set.
  4. <tuffty/>
    21,386
    3,940
    I would be tempted to get an alignment test first in case its something simple...
    Bush wise, poly bushes are ok for the front of the front arms but stick to OEM TT/S3 non voided bushes for the rear bushes in the front arms... I found some bushes on ebay for about 8 quid the pair posted and they are fine. I have Powerflex in the front set of the front arms and the solid (non voided) rubber bushes in the rear of the arms (front arms have 2 sets of bushes). Poly bushes in the rear tend to squeeze out and split.
    Audi will try and sell you a replacement arm with bushes already in it (std bushes) as it is cheaper for them to replace the arm as a whole then to remove and press in new bushes labour wise...
    One other thing to check is the state of your tyres... when my fronts start getting a bit worn the car tends to track a little more....
  5. tankie2ndrtr
    tankie2ndrtr Member
    211
    go for a 4 wheel Laser Alignment. and check Tire wear on the inside :) Think its about £80 :) Not a bad price and it will feel like new
  6. AudiiduA
    AudiiduA Member
    359
    I had a similar problem on a Celica few years ago, it needed track rod end ball joints! wich made sense as there was play in them and the tracking was constantly altering slightly over bumps ect! had them fitted and then tracked and it was like new!
    ATB Lee
  7. martin g
    martin g [censored]
    154
    anyone know of a place to laser align in the somersetish area??
  8. jesters3
    jesters3 Active Member VCDS Map User
    1,516
    Mine had a fidgety rear, came down to replacing the ARB Droplinks (£15.00 a side and 5 mins on a ramp) as the original ones had some play in them
  9. Matt82
    Matt82 Active Member
    2,365
    at 110K miles the bushes will be well past their best. the front end is so simple to do, id start there and maybe drop links
    ive not played about with the rear end of an S3 (independant) but i cant imagine those bushes being particularly good either
