10mm spacers
Chriscooke Mar 26, 2014
  1. Chriscooke
    Chriscooke Clueless!
    512
    25
    I'm tempted to add some 10mm spacers all around to my qts. Do any of you guys have experience with spacers and can suggest somewhere that sells decent hub centric items which don't cost the earth?
  2. aragorn
    18,579
    868
  3. Chriscooke
    512
    25
    I saw those but was hoping someone would be able to point me towards some very much the same but for less money, I'm a little stingy at the moment as I'm trying to get my nissan back on the road this month.
    Edit: Cheers for the link though :)
  4. Bradderz_1988
    3,982
    261
    10mm will take the wheels to an offset of ET25 which imo will be to much poke on a TQS.
    Maybe go 5mm ??
  5. slepy
    slepy Extremely smart and handsome person. VCDS Map User
    2,116
    356
    If you want to get spacers, use only quality ones. I had some **** spacers before which have cracked in half and it was an accident waiting to happen.
  6. Chriscooke
    512
    25
    Could be right on the poke. Do they do 5mm hub centric though?
    Fitted a 5mm spacer earlier and it looked ok but I wouldn't use that type of spacer on my car.
  7. Bradderz_1988
    3,982
    261
    Take it was a shim and not a actuall spacer ??
    http://bit.ly/1cteDlp
    Will need bolts aswell and price is probably £20 not £200 lol !!
  8. Chriscooke
    512
    25
    Yep just a cheap halfords slip on job. Awful thing.
  9. michaelg1001
    michaelg1001 Active Member
    206
    30
    As far as I'm aware, the smallest hubcentric spacers you can get are 8mm from H&R. I asked the very same question when I put my B7 wheels (ET42) on my S4 as they wouldn't clear the brakes.
  10. PaulJC84
    PaulJC84 Owner
    2,921
    17
    What wheels are you running as the standard 7" wide boleros are not et35 like the 8" ones. I think they are et43 off the top of my head.
  11. Bradderz_1988
    3,982
    261
    He has 8" et35 boleros same as my wheels there the votex option !! Standard are ET45 iirc.
  12. PaulJC84
    PaulJC84 Owner
    2,921
    17
    Ah cool, I never knew they were an option on the B5's. I thought they were off the older S6's.
    Would quite like a set to replace my skinny ones.
  13. Bradderz_1988
    3,982
    261
    Think they were votex option on something from 97' as thats when mine are date stamped on the centre caps.
    edit: link for S6 alloy which is ET40
    Bolero Wheels Infomation
