10mm lowering springs out of the factory with S3s with the 18" wheel upgrade???
Westy Feb 1, 2010
  1. Westy
    Westy Well-Known Member
    17,441
    1,098
    I've seen an advert for standard S3 suspension but the seller says that the springs lower the car 10mm more than the normal S3 springs because it was a factory upgrade with the 18" wheels. Does anyone know if this is true because I've not heard this before?
  2. s3 Hoggy
    s3 Hoggy Whats going on???
    1,716
    155
    I've heard that before also that most imports have it too? I'm sure I read it on here (would check if the search was working) might be a load of rubish though,
    Cheers matt
  3. Westy
    17,441
    1,098
    Well I'm probably going to buy the stuff anyway because I need a rear shock only but the seller wants to get rid of all of it. If the springs do apply a 10mm drop I'll be sticking them on too :)
  4. s3 Hoggy
    1,716
    155
    I need a pasenger side rear shock
  5. s3ollie
    s3ollie Member
    762
    Ive heard talk of GMBH suspension option being lower than standard
  6. s3 Hoggy
    1,716
    155
    what the flip is GMBH?
  7. s3ollie
    s3ollie Member
    762
  8. s3ollie
    s3ollie Member
    762
    GMBH is the German equivalent to the English Ltd company. not sure what it has to do with suspension though
  9. Westy
    17,441
    1,098
    Cheers guys doesn't clear it up 100% though. Anyway I've cut a deal with the seller and I'm picking the stuff up this week.
    Hoggy, I should be able to sort you out a rear shock for a small fee in a week or two if you're interested.
  10. s3 Hoggy
    1,716
    155
    Yeah that would be great mate pm me when you know what you want for it
    Cheers Matt
  11. 08080808
    08080808 Member
    i think this is when they updated the tt and gave it lowered suspension, the grey headlights and 18' alloys as standard. i believe they put this onto the s3 also around the same time. also i have just changed up from my standard sus, so if anyone needs any spares you are more than welcome!
  12. Westy
    17,441
    1,098
    Does anyone actually know if this is fact or not?
    Is there anyone on here that ordered their S3 from new and bought this upgrade from the stealers?
  13. jojo
    jojo Looking for Boost! Staff Member Moderator Team Daytona quattro Audi S3 Audi A6 Audi Avant Owner Group
    28,826
    3,479
    Shame the search function isn't working, IIRC, S3's specc'd in Europe(exc. UK) had the option of sport suspension, which was basically GmbH Springs which lowered the car by an additional 10mm. Later facelift S3's with optional 18" RSTT alloys came with this setup, when you specc'd the 18" rims. Not 100% sure.
  14. Westy
    17,441
    1,098
    I'm picking all the shocks and springs up tomorrow so I'll have to check with my shock and springs this weekend to see if there's much of a difference.
    I dont suppose anyone has a decent suspension change guide, especially a rear one?
  15. jojo
    28,826
    3,479
    If you can manage the fronts without a guide, the rears will take 10 minutes each side when you have a look! Just remember to undo the height level sensor on the passenger side of the car, it's bolted onto the track arms, or it will get damaged.
  16. Westy
    17,441
    1,098
    Do I need spring clamps?
  17. jojo
    28,826
    3,479
    Not for the rear, a set of axle stands would be handy though.
  18. Westy
    17,441
    1,098
    So I will for the fronts? I'm going to do the whole lot if the shocks and springs are the 10mm upgrade ones, they've also done 25k miles less than mine have.
  19. MIKE GTR
    MIKE GTR Member
    366
    Just have a brave mate hold them
  20. Westy
    17,441
    1,098
    Brave and strong!
  21. jojo
    28,826
    3,479
  22. Westy
    17,441
    1,098
    Jojo you are a legend. Now I need to clear up whether they are 20mm lower or 10mm lower!
  23. [Dave B]
    [Dave B] Daddy
    2,027
    145
    My car has this option, I believe it is 10mm lower, although you'd be hard pressed to notice it...
  24. Westy
    17,441
    1,098
    Did you buy the car from new? I'm guessing it has/had RSTT wheels?
    I think i'll be putting all this suspension on at the weekend :)
  25. JS1500
    JS1500 Howdy
    1,166
    10
    I think I must have this setup then. As far as I know my car (Jan 2003) was bought new with 18" RSTT upgrade.
  26. Westy
    17,441
    1,098
    The options decoder is a bit **** really as you get loads of weird things and there was no mention or things like my arm rest or Bose upgrades!
    Just stuck all my codes through the decoder and got the following:
    EOA = No Special Edition
    4UF = Drivers and front passenger air bag with front passenger air bag deactivation
    6XD = Exterior mirrors: electrically adjustable/heated
    5SJ = Left exterior mirror: convex
    6TS = Right exterior mirror: aspherical, large viewing field
    1KF = Disc brakes, rear
    S1L = Special price for top coat, metallic
    1LT = Disc brakes, front
    1AT = Electronic stabilization program (ESP)
    3FA = Without roof insert (standard roof)
    1JF = Rear sports shock absorption
    G21 = Front shock absorption
    5TL = Decorative inserts in piano lacquer
    7X0 = Without park distance control
    4R1 = Power windows
    F0A = No special purpose vehicle, standard equipment
    0L2 = Electric throttle actuation
    8GL = Alternator 120 A
    0G4 = Cable gearshift
    0YP = Weight range 14 installation control only, no requirement forecast
    L21 = Suspension range 21 installation control only, no requirement forecast
    T6B = 4-cylinder gasoline engine 1.8 L unit 06A.G
    3NC = Rear seat bench/backrest, split folding
    8JJ = Headlight with gas discharge lamp for driving on the left
    U1B = Instrument insert with mph speedometer, clock, tachometer and trip odometer
    X2B = National sales program Great Britain
    1N4 = Power steering
    2PL = Leather trimmed sports steering wheel for air bag system with "S" badge
    8Q2 = Automatic headlight-range adjustment static
    9Q2 = Multi-function display/on-board computerwith check control
    8Z5 = Not hot country
    MS6 = 4-cyl. turbo gasoline eng. 1.8 L/165 kW multi-point injection, EU 3 base engine is T6B
    7Q0 = Without navigation device
    C4F = Alloy wheels 7.5J x 17
    4X3 = Side air bag front with curtain air bag
    6R2 = Leather gearshift boot
    3L7 = Electric height and backrest adjustment for both front seats
    4K4 = Radio remote controlled central locking
    1SA = Without additional engine guard
    0GE = Emission standard EU3
    Q1E = RECARO sports seats, front
    QG1 = Service interval prolongation
    4GP = Windshield in heat-insulating glass withsunshield and viewing window for vehicleidentification number
  27. Westy
    17,441
    1,098
    Just picked up the shocks and springs. Inheritted the sellers old tie bars too, lucky me!
    Anyway I'll be changing over the leaky shock this weekend then I'll have afew bits and pieces to sell if anyone is in need of anything.
    Just out of interest, if I change all 4 shocks and springs will I need to get a 4 wheel alignment done even though its only going to be 10mm lower?
