1 fault code found during service and no fault light displayed on dash... help!
digikam Jan 5, 2013
  1. digikam
    digikam Member
    Hi all,
    I just got my car serviced at AMD Essex, I have to mention, they provided fantastic customer service! Anyhows...
    1 fault code was found during the service:
    17748: Camshaft position sensor (g40) / engine speed sensor (g28)
    p1340 - 001 - incor. correlation
    readiness: 0110 1101
    No engine light on or any other fault lights and car runs fine.
    However, AMD tech guy did mention it could be that the chain has stretched.
    thoughts anyone???
  2. NHN
    29,331
    1,716
    Assume its a 3.2 then?
  3. digikam
    digikam Member
    yes 3.2
  4. NHN
    29,331
    1,716
    Urm thats not good huh.
  5. chris.vincent3
    chris.vincent3 Own a BMW now, HOWEVER I still own VCDS! VCDS Map User
    604
    34
    Hard to say without someone reading the codes into more depth using VCDS for example. But, it is completely possible for them to be old faults that haven't been cleared.
    As for the chain stretching, when was it last changed? Due to be changed soon?
  6. NHN
    29,331
    1,716
    This is true, but in ideal world you'd expect them to have tried to clear & then if comeback, tell you, problem is,this worlds far from ideal & not even all dealers do this, so chances with indy's is even less unfortunately.
    I always scan before/after to protect myself in 1st instance & also help client out should they have a pre-existing fault.
  7. chris.vincent3
    604
    34
    Yeah, unfortunately things do get forgotten. Digikam, if your chain isn't due to be changed or has recently been changed, i'd seek help from someone that could scan it for you, and just hope the faults don't come back.
    Yeah Danny did that when he fitted my cruise control, he knew my boot light had been unplugged (from having the boot open in the forecourt) otherwise I'd probably not have known to this day now.
  8. digikam
    digikam Member
    engine light has now come on!. i find it strange for it to happen after service. first time i seen the engine light since purchase. car was purchased recently so not sure if chain was replaced.
    my brother will be taking the car to his mates garage tomorrow so will see what that returns. he has all the tools to check.
  9. NHN
    29,331
    1,716
  10. digikam
    digikam Member
    Amd quoted me 1200 for parts and labour to fix this but again i am not sure if the chain is the problem. Are there any obvious visual/sound signs for this problem?
  11. NHN
    29,331
    1,716
    Either they're underestimating the problem or they've got the wrong fault, I remember Paddy spending 10k to find his fault on a car not even worth maybe half that now.
  12. digikam
    digikam Member
    They mentiond as mine is dsg, apparently labour should not be as intensive as doing a manual model
  13. chris.vincent3
    604
    34
    Never knew the chain was a lifetime item as they obviously stretch. I was told that when they get noisy it's a symptom they need changing, however I was under the impression that the chains where replaced not as often as a belt just regularly throughout the engines life so what I know isn't of much help unfortunately as I could be wrong.
    But a stretched chain will put the timing out and make it run like a bag of nails, but other things could also make it run bad, it would be a massive assumption to believe its the chain but if its a common problem and by the sound of it, it is and it's already been diagnosed as the chain you might want to look at replacing it unfortunately.
  14. digikam
    digikam Member
    the car runs near perfect... just need to replace the exhaust to fix the leak on the flex section. engine sound is normal.. no rattles etc.
    the garage have assumed its a stretched chain because they seen the same fault on other cars and apparently it went away when they replaced the chain.
  15. digikam
    digikam Member
    good news! just got an as new catalytic converter fitted to my car at nirro. total cost including part came to 290. car running very smooth now and vagcom has returned no faults. looks like the blown flexi was causing the series of faults that occured before.
