1.9TDI (Pre facelift) Start and Dies after a second (starts maybe 4th attempt)
jonnycraig Aug 10, 2011
  1. jonnycraig
    jonnycraig Member
    157
    Hi all,
    have done a bit of research as best I can on this and a lot of answers come back to the key and trying the spare incase of a dodgy transponder. Ive not had chance to vagcom it yet to see if any codes come up as im 330 miles from home. So my question anything obvious I can check if it doesnt start at all (no flashng lights on the dash like the immob light it goes out and the alarm is def off when I open the car) and how much will it cost to get a key copied and reprogrammed.
    Im based in south wales normally is there anyone with any contacts to get it done for cost (cheaply as Im mega skint!! :p)
    Thanks guys
    Jonny
  2. dieselfitter251
    dieselfitter251 Blow ma own trumpet?
    1,120
    Seriously check the main earth from the battery, it may be way off the mark but this caught me out when I was in Aberdeen. I very sheeping when the RAC dude sorted it with a 10ml spanner, some wire wool and a skoosh of wd40.
  3. jonnycraig
    jonnycraig Member
    157
    Cheers Ill give that a go as its really easy to do, Ive noticed that the immob light sometimes flashes (resulting in a non start) key out and back in, try again usually on 2nd or 3rd go it goes out and I can start the engine. Seems to be getting worse but I suppose the car is 15 years old.
    Jonny
  4. adamss24
    adamss24 Well-Known Member
    4,584
    405
    You need the coil reader wiring from dealer, it's cheap, about 15-20 quid. That will cure the key low signal code... 30 minutes to fit as well !
