1.9Tdi keeps loosing boost
doublem_1 Feb 27, 2011
  1. doublem_1
    doublem_1 Member
    499
    I have a 2002 1.9Tdi 130 A3 and its happened twice now. I have been accelerating and all of a sudden theres a loss of power, no bang or warning lights. Just the turbo stops working, I certainly can't feel or hear it. Yet when I switch the engine off and then back on again, all is fine.
    The second time it happened it stopped at about 3k revs.
    Anyone know what this could be?
  2. sportstractor
    sportstractor Chugger
    2,709
    Could easily be a boost leak or dodgy maf throwing it into limp mode. Get checking the pipes, listening for leaks when loading up. Ideally needs scanning for faults too, as it will report a fault which may not bring up a dash warning light
  3. deian3387
    deian3387 Member
    86
    It could be a sticky acctuator on your turbo, turbo over boosting and going in to limp mode.
  4. JS1500
    JS1500 Howdy
    1,166
    10
    Sounds like a diesel to me.
    Sorry.
  5. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    If it is clearing after restarting ignition, its going into limp mode, you need to get it on the computer mate really....it could be anything
  6. doublem_1
    doublem_1 Member
    499
    Ok thanks for the replies guys. Will have to find someone local with vagcom!
  7. s3dave
    10,110
    736
    Where are you ? theres a vcds user map on here on the main listings....
    There are not many diesel fans on here , so sorry for the poor response...if the guys could help you they certainly would.
  8. Kave
    Kave Member
    160
  9. doublem_1
    doublem_1 Member
    499
    Thanks very much for the help s3dave and kave. I'll try them out.
    I am in Bristol by the way.
  10. a3tdi2001
    a3tdi2001 Member
    437
    It's worth checking the vacum hoses under the bonnet. My car was giving fault code 17964 - Charge Pressure Control: Negative Deviation, which turned out to be from on of the hoses collapsing in on itself as it was perished. Fixed by buying 2m of 4mm, and 3m of 3mm silicone hose from these guys - eBay My World - silicone_hose_world.
    Probably worth changing the hoses as an elimination attempt before you pay someone to get wired in about the turbo or valves.
