1.9tdi air intake / induction noise
middy
yorkshire
hi all ,
dont suppose anyone has a picture / schematic view of the induction system for a 2005 1.9 tdi bkc engine by any chance , ive got a booming noise on acceleration and was wondering where all the joints are and which has orings etc before i start to strip it down to check hoses etc
cheers mark
HTH :)
q To turbocharger2 - Air mass meter -G70-q Removing and installing → Chapter3 - O-ringq Renew if damaged4 - 8 Nm5 - Air cleaner housing (top section)q Clean out salt deposits, dirt and leaves, etc.6 - 8 Nm7 - Vacuum hoseq To solenoid valve block8 - Air filter elementq Always use genuine part for air filter elementq Observe change intervals → Booklet808q Removing and installing → Chapter9 - Air ductq To lock carrierq Clean out dirt, leaves and salt deposits10 - Air cleaner housing (bottom section)q Clean out dirt, leaves and salt depositsq Blow out water drain (small hole in bottom section of air cleaner housing) with compressed air11 - 10 Nm
cheers paddy ,dont suppose you have any info on turbo - intercooler hoses do you :) cheers
the wife aint concerned about the back end cheers N8 , she'll scrape any bumper which is on regardless lol
Is this what you need ?
2 - Bracketq Note installation position3 - Charge air coolerq Removing and installing → Chapter4 - Air hoseq Must be free of oil and grease when installing.5 - 8 Nm6 - To turbocharger7 - Air pipeq Must be free of oil and grease when installing.8 - To intake manifold flap motor -V157-9 - Vacuum reservoir10 - 15 Nm11 - 8 Nm12 - O-ringq Renew13 - Charge air pressure sender -G31-/intake air temperature sender -G42-14 - 3 Nm
