  1. cruisinbeatz
    cruisinbeatz Member
    71
    Hey all, im getting a few things done to the car and I am thinking of getting a remap not to far away. 1 thing i do wonder though. I had a 110 toledo remapped to 145 and i noticed a shudder when accelerating in the higher gears. I also got my last passat 130 awx remapped to 166 and noticed the same on it. Is this a common fault with remapping or whats the deal?
  2. Turbo unit
    Turbo unit Member
    93
    if it was mapped by the same tuner then i would put it down to the map and use some 1 else
  3. adamss24
    adamss24 Well-Known Member
    4,584
    405
    The shudder is compressor surge, don't step on it from low revs in high gear, drop a gear or two if necessary. Also the flywheel is going to rumble as well due to increase in torque...
  4. cruisinbeatz
    cruisinbeatz Member
    71
    Yea they were both done by quantium remaps before. So you think it's natural enough to get some shudder?
  5. adamss24
    4,584
    405
    Too much torque upsets the flywheel, hence the shudder. You need to get new flywheel or upgrade to single mass flywheel and stronger clutch with organic linings !
  6. bobby singh
    bobby singh BSR VCDS Map User quattro Audi A4 TDi
    364
    178
    43
    Adam is right too much torque.
    I would try and get a more progressive map and save your running gear. I've done these cars upto 220hp on a vnt17 hybrid no issues.
