Hi folks, has anyone experienced premature failure on a water pump?
I did timing belt & tensioner a etc, aux belt, water pump and coolant change 9k miles ago and just today noticed a coolant leak dripping from the bottom of the engine snub mount at the front. Above that is the crank pulls which is wet with coolant. I've taken the upper timing belt cover off but can't see enough of the water pump pulley to confirm leak is coming from there but don't see where else it'd be coming from to emerge from above crank pulley.
No evidence of leaks elsewhere including around bottom of radiator.
I used a gates timing belt kit and Febi water pump and replaced coolant too so assumed I'd have peace of mind.
When fitting water pump I did everything by the book, cleaned mating faces, lubed o ring etc, so I'm confident it was all fitted correctly.
I'm assuming either knackered pump bearing (in which case coolant would be forced out of weep hole) or failed o ring that seals pump to block. Can't tell without pulling the lock carrier off I guess, and it all means doing the whole damn timing belt rigmarole again too
Any other thoughts appreciated!
