1.9tdi 100bhp, 115bhp, 130bhp
p1tse Jan 9, 2011
  1. ASHIHARA
    ASHIHARA Member
    294
    15
    Well,AVF have a stronger clutch,240mm vs 228mm AVX;some people says the extra 25nm came for the map,other people says came from the gearbox;to be honest,i dont know the true.
    But bowth engines technical are the same.
    AVF cant take 450nm till 500nm
    AWX cant take till 400nm,most remaps are 370-380nm tourque
  2. simon.m
    simon.m Active Member
    2,747
    i think mine is the AVB engine being the 100bph
  3. ASHIHARA
    ASHIHARA Member
    294
    15
    AVB is good in fuel economy,but not so great in power:
    AVB 12,1sec 0-62mph
    AVW,AVF 9,9sec 0-62mph
  4. simon.m
    2,747
    It gets me there lol
  5. Bari
    Bari Member
    97
    13
    i think makes difference on the turbo
    100hp - gt15
    115 gt1749v
    130 gt1749va
  6. ASHIHARA
    ASHIHARA Member
    294
    15
    I just explained the diferences,they are not only on the turbo.
  7. Bari
    Bari Member
    97
    13
    right :D
  8. adamss24
    adamss24 Well-Known Member
    4,584
    406
    They are all technically GT 15 but Garrett are making the matters even more confusing when they are reffered as VNT1749x(x) ?! The 110Bhp VE and 115Bhp PD IS the same GT1749v turbocharger(the later has a larger intercooler and higher injector pressures hence the low bhp difference but the Nm increase), the pd 130 is a GT1749VA(few mm bigger compressor wheel), the golf/bora PD 150 is a GT1749VB (the largest fitted VNT17 with integral manifold) wich feature a new mix of alloy and can sustain higher boost and higher EGT. This wont fit a longitudinal engine as its mounted the wrong way.
  9. ASHIHARA
    ASHIHARA Member
    294
    15
    Turbos 150hp pd are not mounted in the wrong way,they are just for transversal engines :)
  10. adamss24
    4,584
    406
    I meant they are clocked the wrong way for a longitudinal engine and under the bulkhead as opposed to beeing on top compared to the passat (bit like my girlfriend when we make sex: she wants me to be on top and i wanna be under !)...
  11. ASHIHARA
    ASHIHARA Member
    294
    15
    I know what u mean :);anyway,good udpgradet for longitudinal engines is pd 170hp turbo bv43,is plug and play.Im use one for myself.
  12. Bari
    Bari Member
    97
    13
    right... i want one too :)
  13. ASHIHARA
    ASHIHARA Member
    294
    15
    Ha,ha,ha,u have a bigger turbo like bv43 :)
  14. Bari
    Bari Member
    97
    13
    not now.. i sold the 2260 and i have gt1749va again lol
  15. MarkWizard
    MarkWizard Member VCDS Map User
    148
    Don't see how it could be the gearbox as torque / bhp is measured at flywheel for manufacturers figures, must be map
  16. ASHIHARA
    ASHIHARA Member
    294
    15
    U right,i didnt think about that :)
  17. MarkWizard
    148
    No worries mate! Can I ask why brakes from a B5?
  18. ASHIHARA
    ASHIHARA Member
    294
    15
  19. Bari
    Bari Member
    97
    13
    and they are plug and play :)
  20. ASHIHARA
    ASHIHARA Member
    294
    15
    yes,they are;the only thing is you must have ET43 wheels 17 or 18inch,or u have to use wheel spacers;16inch wheel dont fit s4 calipers!
    @Bari,why u sold that turbo?why dont u go bigger?,like 3,0tdi 240hp turbo?Is true,in this case injectors dont have flow and is underfueel
  21. Bari
    Bari Member
    97
    13
    yes, in that case better injectores will be needed...
    here in Portugal we have Ibizas PD 130 with more than 300hp, i know one with 370 :)
    but the engine blows... i think
  22. ASHIHARA
    ASHIHARA Member
    294
    15
    Yes,is true,stock engine cant handle more 250hp,i think 200hp is safe on long term.
  23. Bari
    Bari Member
    97
    13
    yes it is ;)
    for 200hp kkk bv43 is enough ;)
  24. Sorry to drag this thread up, but with the bv43 turbo bolted onto awx engine and good map will the injectors need upgrading or are they ok with the standard ones?
  25. Harribo66
    Harribo66 Member
    163
    i would like to know this, but for a avf engine.
    Cheers,
  26. adamss24
    4,584
    406
    The stock injectors are fine with just the BV43...
  27. QUIGGS2001
    QUIGGS2001 New Member
    20
    Dont want to come across as rude, but I own a 04 1.9 TDI A4 Avant Sport. Its a 115. Almost certain its PD. Engine code BKE.
  28. dannott90
    dannott90 New Member
    does anyone have any info on the PD115 BRB engines? mines been pretty solid soo far, are there any known problems with them?
    mines been mapped by R-tech in Leicester for around a year or so now to roughly 150bhp with 285 ftlb's of torque with no problems with the clutch or flywheel.
