1.9 TDi suspension problem
petemac Mar 29, 2010
  1. petemac
    petemac New Member
    I have just bought an A4 1.9TDi. When I go over a bump / pot hole and the suspension expands after damping the bump, the car wobbles to the left. Like the back end wobbles to the left. I think its on passanger side, not to sure. Could this be a buggered spring, bush or shockie? Any ideas? Also one of the wheels needs balanced, not sure if this is connected.
  2. L4FOU
    L4FOU New Member
    10
    Hi did you get this problem sorted? seem to be having the same issue with mine of late where the back sways right - feels like I'm on a swing bike after sudden swerve or going into pot holes. definitely need to get this looked at asap - idea feedback welcomed
    Many thanks
  3. aragorn
    17,889
    689
    shocks can be checked by doing the bounce test. Open the boot and press down on one corner then release. If the shocks are good the car should rise, then settle immediately, if it oscillates then the shocks are worn
    Could be the rear axle bushes?
  4. L4FOU
    L4FOU New Member
    10
    Hiya - tried the shock test all seems ok so I reckon it's the arb or as you say could be bushes. will get this looked at tomorrow....aaarggg...just when I thought me and the bank manager we getting back on good terms...spent a small fortune on new injectors 6 weeks ago. got some used 130PD injectors for sale if anyone's interested - one definitely needs a service but not sure which
    thanks all the same aragorn
