1.9 tdi starts rough after cold nights
Wheeler97 Nov 21, 2008
  1. Wheeler97
    Wheeler97 New Member
    10
    It starts but not like it should.
    Glow plugs OK.
    Battery OK.
    Fuel filter changed recently.
    :blackrs4:
  2. benr
    benr Member
    819
    Mine always sounds rough until its warmed up and then it sounds like a beautiful diesel sound.
    Every derv ive driven has been the same i think.
  3. Wheeler97
    10
    It STARTS rough (all diesels run rough after start in winter), but mine STARTS rough.:cold:
  4. benr
    benr Member
    819
    I see i dont understand what that means... this forum doesnt get much coverage, possibly get more if you post in the A3 or A4 section
    Vag-com not bringing up anything?
  5. Wheeler97
    10
    I think first I will try to adjust ignition timing, if that doesn't work I will connect to VAG COM (it will probably be a sensor then).It's so annoying, I also have a power loss, my a3 isn't a pocket-rocket when engine is fine and now it drives almost as SDI. I guess that whats happens when you have an old diesel problems problems problems
  6. dieselfitter251
    dieselfitter251 Blow ma own trumpet?
    1,120
    234K on the clock, anywhere below 2oC. Sounds like Lemmy from Motorhead gargling with a bag o bolts!! Give it five minutes and it just sounds like a bag o bolts.... Ah the glorious derv.
