1.9 Tdi Shreading Auxilliary Drive Belts ?
robert97r Feb 22, 2007
  1. robert97r
    robert97r New Member
    22
    In the last 5 months ( 6,000 mls ) my '76 A4 Tdi 110 has shed 2 and is currently on it's 3rd Aux Drive Belt ( Fan; Power Steering and Alternator Belt )
    As the current Belt is still fitted I can see that it seems to be riding over the Pulley Ribs towards the front of the car, this suggests that there is an alignment problem but why after 150,000 mls in my ownership should this start happening ?
    Robert.
  2. treblesykes
    treblesykes Member
    690
    dont know for sure but try checking the tensioner,maybe be short of tension or wobbly
  3. robert97r
    22
    Good suggestion, would account for Belt crossing over Pulley Ribs, I also have a '98 A4 so will compare Tensioner forces. Will report back.
    Robert.
  4. robert97r
    22
    Latest Belt fitted and will monitor daily ( ? ) Compared Tensioners on both Audis and the seem the same. Spoke with Continental who manufactured the Belts, they were very receptive of the concern and will talk with their German colleagues and supply feedback.
    Robert.
  5. shineydave
    shineydave Member
    920
    could it be worn bearings in one of the driven components?
  6. goon
    goon Member
    332
    try putting a straight edge(steel rule etc)across the 2 pulleys to check alignment
  7. marmite
    marmite Counting the Tesco Club points
    1,101
    THis used to be a common fault and the tensioner needed to be replaced, we used to get loads of cars coming in with snapped belts
    When looking down at the engine from the n/s you can see the pully on the poly belt tensioner, the spring goes out of shape and the tensioner pully goes out of alignment causing the belt to snap
    Job is fairly straight forward but the bolt holding the tensioner can be very tight and seize in plus you need a special tools to hold it steady while you undo the bolt
