1.9 tdi service kit
mattyb6 Nov 21, 2012
  1. mattyb6
    mattyb6 Active Member
    977
    75
    been to audi dealers the other day and asked for a price on a service kit
    bloke at the parts dept. had never heard of PD oil
    i heard that correct PD oil had to be used
    also, how much have you payed for a full service kit
    inc. pollen filter
    oil filter
    oil
    glow plugs
    fuel filter
    thanks
  2. stu_m
    stu_m Well-Known Member VCDS Map User
    1,440
    Euro car parts is where you want to be with a promo code midmonth30 which gives 30% off
    I just got everything for 52 quid
    By the way if your car starts ok I wouldn't bother with glow plugs
  3. mattyb6
    977
    75
    On start up its very jumpy, and idles sloppy for a minute or 2
    Whats the best oil to get then?
  4. stu_m
    1,440
    does it start first turn without a struggle? if so the glow plugs are fine the lumpyness could be something else light syncro angle out slightly mine was lumpy till i did my cam belt and put my syncro angle to 0
    put your reg in to euro car parts it will give you the list of parts
    you want 5/30 fully synthetic its about £39 but with the promo code you can get the lot for about 50
  5. mattyb6
    977
    75
    Been today and got everything in glow plugs for £70
    what is the syncro angle? Only is lumpy when cold, idles mint when warm and after 2mins of being started
  6. chris1008
    chris1008 Member
    118
    You can use any oil in these as autodata says, don't need a specific oil so you can save some money next time round. Mine runs on 10w40 no frills semi synthetic stuff absolutley fine.
    I paid about £25 for my pollen, oil and fuel filter
  7. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    I just got oil filter ,sump plug pollen and air filter and fuel filter , wipers for £52 from VW
  8. adamss24
    adamss24 Well-Known Member
    4,584
    405
    That's not true ! The PD engine requires fully synthetic oil conforming to 505.01 or 507 VW norm, nothing else works in these without wearing the cam lobes and lifters ! I would go for oil to TPS or local VAG dealer, fully syn. 5w40 oil PD spec is about 35 quid for 5 liters...
  9. gen.heinz guderian
    1,346
    126
    The cams / lobes wear ,even with fully synthetic oil !!!
  10. chris1008
    chris1008 Member
    118
    B0llocks, why would the cams wear more ? that is just general wear and tear. Auto data says 5w40, 5w30 10w40 moderate temperatures. Audi would say that so you go and buy the expensive stuff, suppose they'd say it needs the low ash stuff too
    it's due for servicing soon, give it a couple hundred more miles or so as the car is running oil Bio diesel at the moment for the last 2 weeks, so I'm going to give it chance to clean all the scaling out of the tank into the filter. Then i will change the lot including new 10w40 castrol diesel stuff, could'nt turn it down for a tenner :)
  11. marktdisport
    marktdisport Active Member
    1,195
    15
    Lol this is going to be a good thread like the old mpg arguments
