1.9 TDI Serious Clutch Pedal Vibration
matt_splatt Apr 11, 2004
  1. matt_splatt
    matt_splatt New Member
    I drive a 2000 A6 1.9 TDI that has developed a vibration that can be felt through the clutch pedal. I'm after any opinions on the possible cause before I get fobbed off by a dealer.
    Symptoms are :-
    Clutch bites high, but I understand that this isn't unusual
    Vibration is directly linked to engine speed.
    Can be felt by just pressing the clutch 5mm, right down to the carpet.
    No slipping problems
    Engine is running smoothly.
    Any clues appreciated...
  2. peteA3tdi
    peteA3tdi Member
    408
    all vag tdi's i have driven have a vibration on the clutch pedal if you press it lighty about 5mm pressing it more and it go's away
  3. matt_splatt
    I could live with that, but this one doesn't go away. It's there even when the pedal hits the carpet.
    It's 'duh duh duh duh duh' at idle and 'de de de de de' as the revs increase. In gear or neutral, moving or stationary.
  4. mastertech
    mastertech Member
    41
    COULD BE THE DUAL MASS FLYWHEEL
