1.9 TDI Oil return pipe leaking
ruffrida Sep 25, 2012
  1. ruffrida
    ruffrida Well-Known Member
    1,937
    315
    Afternoon All,
    Noticed a bit of an oil leak the other day (left the under tray for a day).
    On further inspection it is coming from the oil return pipe at the engine end between the pipe and the block, so not the pipe its self.
    I am going to be doing an oil change at the weekend, but just wanted to know if this could be a dodgy washer or is it worth replacing the whole pipe?
    And does anyone have any diagrams or know where i can get one from, just to make sure everything is as it should be once removed?
  2. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    Sounds like the copper washers are weeping a little, if it was me I'd get a pair of washers and a new banjo bolt from TPS and replace it
  3. ruffrida
    1,937
    315
