1.9 TDi Issues
G111MDS Jun 19, 2012
  1. G111MDS
    G111MDS Member
    68
    Hi - tryed to do a search on the site but for some reason none of the thumbnails are showing which is making it hard to follow.We've got a 98 A4 1.9 TDi with nearly 160K on the clock. a couple of times recently it has been a little bit hesitant some times when accelerating, nothing too bad but noticeable all the same. there is plenty of fuel in it. This morning, it has cut out twice after being started, and the sorted itself out and seems to be running ok.Any ideas what the issue may be?Many thanks, Jamie
  2. Bradderz_1988
    3,958
    240
    Try blanking off the egr valve to rule it out on that sort of milage it may be heavilly clogged up.
  3. G111MDS
    G111MDS Member
    68
    will give that a shot, thanks. Is it relatively easy to do and woudl you able to blank it off long term?
  4. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,162
    1,123
    yeah.
    Just shove a sheet of metal cut to size, drill two holes and put it between the EGR and or pipe.
    It will stop the exhaust gasses from going back in to the engine.
    Mines been blanked off for about 25k with no issues.
  5. G111MDS
    G111MDS Member
    68
    excellent, thank you! a job for the weekend!Cheers, Jamie
