1.9 tdi engine mount fault code on vcds
glenandem Feb 5, 2013
  1. glenandem
    glenandem Active Member
    786
    64
    hi guys,getting the int fault code on engine mount on my vcds and it wont clear, ive checked the mount with the plug on it quickly and no leaks but has a buldge in the rubber holding the fluid in, couldnt see the other mounting on drivers side as it was too wet to get underneath but will check it, now im getting a bad vibration when setting off and best way to stop it is to slip the clutch with high revs and im getting a monster vibration at mway speed, could this be due to a engine mount or could it be the dmf, the engine doesnt idle bad neither does it shake the car bad either unless setting off or on mway.
    im just not sure which to go for,if the drivers side mount isnt leaking am i right in thinking dmf and thats causing the engine mount fault code but then again the code wont clear even when im stationary so no had time to rattle the engine again to set it off????
    confuseddddddd!!!!
  2. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,819
    197
    Im not too sure but these engine mounts stiffen up at speed, and slack at idle to reduce vibrations i think i read this somewhere. If the mount is bulging and you have a fault code, id replace it!
  3. glenandem
    786
    64
    jacked the engine up today while i was fitting my s line lower and the drivers engine mount looked spot on and was still together after trying to gently jack the engine up so its not separated!
    cant understand why im getting the fault when it all seems ok,no leaks etc?
  4. Have you checked the passenger side? thats the side that has gone on mine, i will get round to it one of these days, but wont pay tps price of 100quid for a new one, german ebay however do sell them new at half the price
  5. glenandem
    786
    64
    hi mate,checked that yesterday as you can pretty much see that by looking in engine bay but did have look underneath and there wasnt any red fluid or any sort of wetness as i thought thats what makes them go faulty?
  6. crazy88
    crazy88 Loving the anonymity
    4,939
    438
    It's not just a wiring fault is it? Checked the cables are all ok?
  7. glenandem
    786
    64
    yeah ive not checked the wiring loom or plug yet, just checked for leaks splits etc but next thing to do!
  8. lukey baby
    lukey baby Member
    106
    12
    I changed both of the engine mounts on my b7 as i was getting a really bad vibration at 1750rpm. When i had them out i could not see anything wrong with them compared to the new ones but it did cure my problem.
