1.9 tdi 130bhp fwd vs quattro mpg
p1tse Mar 6, 2011
  1. p1tse
    p1tse Member
    797
    24
    What are the differences.
    Owners here worst and best mpg/ miles per tank etc?
  2. quattrojames
    14,060
    583
    Quattro normally costs 3-5 mpg.
  3. Funkyfin2000
    Funkyfin2000 Member
    489
    My quatty gets 30 - 38mpg on short runs.
    Yesterday on a long run at 70mph for 150 miles I got maxed out at 42mpg. Highiest I've seen with very careful driving is 44mpg.
    New Coolant Temp Sender, Just been fully serviced, oil, fuel filter, oil filter, air filter etc and had the EGR and Manifold cleaned and so it's pretty top notch.
    Recently had injector cleaner through so I expect that's as good as it gets!
    Rich
  4. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,811
    54
    the 4 wheel drive set up will cost you more to run as its got more power to be used by the motor + the extra weight.
  5. Avant4me
    Avant4me The're Graphite not black!!
    257
    All my figures are fill to fill as i don't have DIS. Bear in mind 2wd has 70l tank where as quattro has 63L.
    Min 32.3mpg max 448 Miles Comparable range for 2wd tank 498m
    Max 42mpg max dist 592 miles. Comparable range for 2wd tank 659.
    The other day i was on a steady run to Sheffield, had 184 miles on the trip and sat a 78mph i had 520 showing on the range. 704 miles is rather impressive from a quattro. Unfortunately it started dropping when i came off the motorway.
    Mike.M likes this.
  6. quattrojames
    14,060
    583
    Sorry to throw your maths out, but to keep the thread accurate, quattro's have a 66 litre tank :)
    That's from the 2003 A4 model range brochure.
  7. MarkWizard
    MarkWizard Member VCDS Map User
    198
    My 2wd averages about 47-48 mpg with a range of 730 miles, I do 130 miles a day mainly motorway at a steady 85ish! On a steady journey on an A road doing 50-60 I can see the range go up to 830ish
  8. benjie
    benjie Well-Known Member
    1,223
    305
    Official figures are 45mpg v. 43mpg.
    In winter my quattro DIS shows 34-38 on a 20min drive to work, 1/2 urban, 1/2 motorway. In summer, it's 38-45. I've seen 50mpg on a long run in summer.
    Though I'd question how reliable the DIS is, but don't have the inclination to work it out properly!
  9. Avant4me
    257
    Nowt wrong with my maths mate, my owners manual lists all the quattro's with a 63l tank. Having had mine completely empty i can verify this too.
  10. scott b
    scott b Active Member VCDS Map User
    1,254
    average mpg on mine is around 43mpg
    motorway its around 50 mpg
    1.9 FWD
  11. quattrojames
    14,060
    583
    Probably a 63 litre tanks and 3 litres in the the lines or something then. I'll have to see what my brochure say's, I've only ever looked in the Audi range brochure, although Parkers state 66 too.
    EDIT I've just been out and checked my manual (like a saddo..) and it definitely lists 66 litres for all quattro models!
  12. Avant4me
    257
    Don't set too much store by parkers, just looked on there for my model avant and they list it as a 70l tank!!
    Its a bit weird that your literature is different to mine. Mine car was registered Feb 04 but is a 53 reg. Manual lists all the 2wds as 70l and ALL of the quattros as 63L.
    There is no way you would get 3l in the lines, 1l would be a push. Would be interesting to know if Audi changed the tanks.
  13. benjie
    1,223
    305
    Is the 63/66L including any expansion/reserve tanks?
  14. quattrojames
    14,060
    583
    I agree Parkers is a bit hit and miss. I can only guess they changed the tank size in late 03/early 04 unless anyone else can offer an explanation?
  15. ASHIHARA
    ASHIHARA Member
    294
    15
    "The fuel tank holds about 70litres on 4 cylinder FWD and 66litres on four-wheel drive models.These figures are only approximate capacites"-from a4 avant owner`s manual 2002.
  16. jbcalvin
    jbcalvin Member
    691
    21
    I normally average 35-38mpg around town, however on a trip to Devon recently from Scotland I averaged 44mpg and that was most of the way at 70-75 on the speedo, although there was a 90 min section in traffic and some back road driving as well....
    With the cruise fitted later this month I expect to average 45mpg on my trip to Le Mans later this year...
  17. simon.m
    simon.m Active Member
    2,747
    my book says the same 66l and 70l
  18. Turkster
    2,811
    54
    dunno about other quattro drivers but when my fuel gage gets into the red, When i turn the car off and restart it, the gage normally sits at 0 point,
  19. TheONEin10
    TheONEin10 New Member
    Ive got a 1.9 quattro and i managed to get 605 miles on a single tank once but that was leaving it until the computer was reading 0 before i refilled. I think i worked it out at about 46mpg if i remember rightly, but that was all motorway work at about 70-80mph
    Normally i get about 25-30mpg though, haha i dont like hanging about. lol
  20. paul20v
    paul20v Audi fanatic
    1,113
    WTF 25-30 are you sure
    i drive my car quite actively and i get no less than 38-40 round town .
  21. p1tse
    p1tse Member
    797
    24
    crickey you don't like to hang about, my 3.2 v6 petrol is like that LOL
  22. matttrs
    matttrs Member
    163
    last week on a full tank I got 590 miles in my quattro avant, does need a service though.
  23. audigeezA4
    audigeezA4 Member
    104
    hi guys
    would really like your opinion as its a burning issue for me- i filled up £50 and i got 240 miles in my b6 2.5tdi quattro, now i must admit i have only had the car 2 weeks so been quite keen, however, the dis stated i avg 25mpg on the 2 setting and 1 setting it regularly displays anything from 15 to 25mpg, with short journeys though mainly and a heavy right foot. would u say my dis is faulty as when i did the maths and converted myself i worked out approx 30mpg???
    any thoughts or tips as i'm a bit concerned there's something wrong????
    ps i checked my manual and it states 63 litres- nov 03 model.
    cheers.
  24. a4 cabrio
    a4 cabrio Member
    135
    thats sounds very low mate, i have a 2.5tdi cabriolet, and am currently gettin just over 36mpg, 30 mile A road commute to work and back. heavy foot in the morning as i am usually late lol.
    i put some reddex(i think thats what its called, £8 halfords) in last week when i filled up and that seems to have helped the mpg a little
  25. audigeezA4
    audigeezA4 Member
    104
    Thanks pal- was thinking of doing that but was a bit hesitant as it says in manual not to add any kind of additive?? But at the same time I assume it can't do any harm- so will try redex an see how it goes. Otherwise I hope it's a faulty dis and nothing more serious.....
    Cheers.
  26. a4 cabrio
    a4 cabrio Member
    135
    i didnt realise additives wasnt supposed to be used. but i put mine in on saturday, so far so good. i was just gonna use it every 3rd or 4th tank full.
    hopefully you get an improvement in mpg some how
  27. ASHIHARA
    ASHIHARA Member
    294
    15
    No,you will not see any improvement in mpg;search google and you will find is only placebo.
  28. quattrojames
    14,060
    583
    Have you worked out actual mpg yet or relied purely on the DIS?
  29. audigeezA4
    audigeezA4 Member
    104
    Morning
    I worked it out manually and I got 30.75mpg if my sums are correct- 250miles,135p/litre,£50 fuel,4.55l in a gallon=8.13gallons~250=30.75mpg. Dis showed 25mpg overall- I have filled up again and reset- now dis showing 18.9mpg???? Quite puzzling tbh??? Also, not convinced redex or similar will help as i assume thats for the fuel filters, but the cars running pretty smooth- I think its gotta be the short journeys- starts and stops etc?????
    Cheers.
  30. vinesh
    vinesh Member
    214
    Instead of Redex, try Forte Diesel treatment. But short journeys will hammer MPG.
    Filters is worth changing - Fuel and Air.
    With all my cars, i always change all the filters every year. Don't like Audi's recommended intervals for filters.
    I get 350-400 miles with £65 of Diesel.
    This is City and motorway driving.
    I find Shell fuel gives better MPG.
  31. audigeezA4
    audigeezA4 Member
    104
    Hi vinesh
    Thanks for that- I will look at the forte diesel product. Cars due for service in a couple of months so will get Audi to look at the filters. I also just filled up with shell- £60 to be exact and trip showed 300 miles so maybe it takes into account driving/journey habits- if I get this then I work out 31.75mpg which is still disappointing.
    Maybe the service will help.
    Thanks for your response.
  32. quattrojames
    14,060
    583
    I get 33mpg as an all round average on mine, so it's not that far off. You must drive it pretty hard though to get less than me!
  33. audigeezA4
    audigeezA4 Member
    104
    yes james- its cos ive only had the car 2 weeks, plus i think my right foot is not connected or fully co-ordinated with the sensible part of my brain yet!!!!:yes:
    plus i'm lovin the sporty sound of the v6 so guess its costing me to hear that everytime i get in the car!!:drool:......i'm a 21 year old in a 41 year old body crying let me out, let me out!! lol
  34. quattrojames
    14,060
    583
    I'm the same. But not quite so old :p
  35. aragorn
    18,577
    868
    Sporty sound? Dont get ahead of yourself... Its a diesel. :p
  36. audigeezA4
    audigeezA4 Member
    104
    well you know what they say... you're as young as the woman you feel, and currently i'm feeling a.....oops....:readit: trouble and strife(wife) might read this.......:tapedshut:
  37. audigeezA4
    audigeezA4 Member
    104
    i know mate, but so glad i got the v6 quattro- tell you what its the best sounding diesel i've ever owned, and i've had a few- mind you i cant believe i'm a german fanboy now, back in the day i was a japboy only- i sometimes miss the good old drift days of my neesaan 200sx and 300zx's..... ok, ok, sacarilidge i know , guess i've grown up a "little" bit since!!!
  38. adamss24
    adamss24 Well-Known Member
    4,584
    407
    Chuck the cats out and it will sound even meaner ! By far the best diesel sound you can get on full throttle !
  39. audigeezA4
    audigeezA4 Member
    104
    100% agree- however, i am against cruelty to animals....(sorry, couldn't help it!! lol). not sure but would catless make the mpg worse????? Mind you, with the fuel consumption i'm currently getting, im thinkin i should gone for the S4......now that V8 sound....bellissimo!!!!!!
  40. p1tse
    p1tse Member
    797
    24
    thanks
    don't see many 1.9tdi quattro's though
