1.9 TDI 130 sport Opinions.
Gedi69 Apr 10, 2014
  1. Gedi69
    Gedi69 V8 Lover
    32
    Hi guys im new to this site and im very much liking it :)
    I am currently going to join the Audi club and am currently looking for my 1st Audi baby lol.
    I have seen a 04 plate saloon and it has done 79k miles and timing and water pump was done 4k miles ago it has a gmbh S line kit on it and it also has a full service history.
    It has MOT till Oct and Tax till June.
    What are your thoughts on a price for this car? it is in very good cond.
    Thanks for your help in advance.
  2. krisavant
    krisavant Active Member
    449
    59
    I'd pay up to £4 grand for it if it was mint including interior etc with no dings dents or rust.
    Obviously full service is good and the miles are low.
    Gedi69 likes this.
  3. Gedi69
    Gedi69 V8 Lover
    32
    Thanks for your reply kris :)
    Have you guys got any tips on what to look out for when buying 1 of these?
  4. TheDriver
    TheDriver Active Member
    260
    I think first and foremost checking that all the carpets are dry and more importantly that there is no standing water inside the plenum chamber - the compartment under the bonnet (directly beneath the windscreen) that houses the battery, ECU, brake fluid reservoir, etc.
    The drain plugs at the bottom of the chamber have a habit of blocking up with debris causing it to fill with water and after getting to a certain level and sploshing about, it starts to run behind the dash and cause havoc with the vehicle electrics.
    The carpet-checking part is in relation to the Comfort Control Convenience Module which is under the passenger footwell. Again, natural flow of the trapped water is sent down that way so it's always good to check that the carpets are all dry, although this being dry in itself does not necessarily mean that there is no issue with water ingress.
    Obviously the electrics behind the dash (drivers side) can be dried out and a good clean out of the plenum chamber (+removal/tailoring of drain plugs) will hopefully prevent it from re-occurring again in the near future, but I believe if the convenience module has been affected they can be a tad costly to replace. Most of all it's just annoying to have a bunch of lights flashing up on the dash and the car going into 'limp mode' every time it rains.
    ruffrida and Gedi69 like this.
  5. TheDriver
    260
    It would also be good to see a clutch/flywheel having been changed at that sort of age/mileage. To be fair my clutch lasted 11 years and 63k and I figures that was pretty good going. New clutch and DMF would set you back approx. £7-£1200 depending where you go.
    Couple of other minors:
    Slow wipers - sign of mechanism/linkage beginning to seize.
    Rear wash/wipe - the washer jet often gets blocked and/or causes the water pipe to pop off it internally often causing water to get sprayed around and causing damage to the wiper motor.
    To be honest they're all minor things, I don't think there's anything majorly disastrous on these cars in particular, unless you go for an auto; they're known to be a bit troublesome at times.. All in all the 1.9TDi 130 is a pretty bulletproof engine, hence variations of which are still being used in their current models today. As mentioned before in other threads, hope to find a stack of receipts showing that the car has been looked after and had money spent on it other than just the routine servicing, which pretty much tells you jack other than it's had some oil and filter/s changed in its life.
    Can't really go to far wrong with them to be honest - cracking car. Good luck!
    EDIT: Actually, I lie. Looks like they use 2.0L engines in the very latest A3/A4 models. Still, the 1.9 had many many years of reliable service across many different makes and platforms.
  6. Gedi69
    Gedi69 V8 Lover
    32
    I will ask about the clutch when it was last done, cheers driver :)
  7. TheDriver
    260
    No probs mate. Yeah, maybe you can use that as a bit of a bargaining tool if it hasn't been done yet, least of all due to the fact that it will cost a fair wedge if you ended up having to change it during your ownership.
  8. ruffrida
    ruffrida Well-Known Member
    1,926
    313
    Can't say much more than above really.
    What I can say is that, I spent a fair few months looking for my b6 and found loads of saloon quattro's around for 4k ish, a few very tidy 1's aswel.But they are just big enough for me. Also all depends what ya lookin for lol
  9. Gedi69
    Gedi69 V8 Lover
    32
    going to look at that B6 tmw so hopefully i drive it home, then i can start modding it :)
  10. ruffrida
    1,926
    313
    Let us know how you get on
    Gedi69 likes this.
  11. Gedi69
    Gedi69 V8 Lover
    32
    What cheap upgrades can I do to one of these to give it some more power?
  12. IanFM
    IanFM Active Member quattro Audi A5 TDi
    452
    81
    in terms of bang for buck a remap should be first on the list every time. Makes the car drive like it should!
  13. TheDriver
    260
    Pound for pound I'd say a remap. Not necessarily cheap but its the biggest power boost you'll get for your money until you start going into the realms of turbos, updated intercoolers, updated injectors, etc.
    Then maybe a decat down pipe. May only give you a couple of bhp if you're lucky but will certainly provide better exhaust flow helping turbo to spool up a bit sooner and slightly better response through the rev range.
  14. Gedi69
    Gedi69 V8 Lover
    32
    How much is a remap roughly, sorry but I've never thought about doing anything to a diesel till I thought about getting an Audi. Now I'm finding out that there's loads I can do to them :)
  15. IanFM
    452
    81
    £ 150 to £250 depending on where you get it done.
  16. TheDriver
    260
    I think you can buy these tuning boxes for something like £45 which does a similar thing. Have a search, a few guys on the forum have them fitted. 'Off the shelf' and 'live' remaps start from around £150 and up towards the £3-£400 mark.
  17. TheDriver
    260
    If you are going to get a remap done it would probably be wiser to get any engine mods you're thinking of getting done first then have a live remap carried out therefore taking into consideration the specific mods your engine is running. Be a bit poo if you paid a load of money to have a remap then end up changing a bunch of stuff which alters the fuelling, intake, etc, then have to fork out for another remap to then get the best out of your engine again. All depends how far you're planning to go and how much money you're willing to throw at the car. There's lots you can do to a turbo-diesel but Beware! It can fast become a wallet-bashing, wife-divorcing, kids inheritance spending addiction!
  18. Gedi69
    Gedi69 V8 Lover
    32
    im not going to go too mad but i do see your point, tbh id just like it to sound a bit nicer and to have some nice styling to it not anything ott just some subtle touchs. it already has the gmbh S line kit on it which i think comes as standard and ive been looking at the rear roof spoiler.
    Cheers guys your such a friendly and helpfull bunch, most other forums are so clicky lol.
  19. TheDriver
    260
    No doubt. The difference a good remap makes is enough for most folk. The B6's look well after a few subtle touches here and there.
    And yeah, it is a good forum :) The guys (and girls) on here all seem pretty genuine, helpful and like to have a good bit of banter without the snottyness and cliquey behaviour reminiscent of other forums I've been a member of. Me likey.... :yes:
    BakPak and Gedi69 like this.
  20. Gedi69
    Gedi69 V8 Lover
    32
    How easy are the roof spoilers to fit? is there much drilling to do?
    If i do get this B6 tmw ill post a pic if its easy enough to do :)
  21. TheDriver
    260
    That I couldn't tell you I'm afraid. Mine's an Avant and already had the roof spoiler fitted so I haven't the foggiest. Google search might bring up something..
  22. Gedi69
    Gedi69 V8 Lover
    32
    Went and saw the car today and brought it it was what the bloke says it was, very clean and well looked after inside and out with only 1 scratch on the rear bumper, although after a test drive I found out that a wheel bearing on the front was shot so I managed to get the price down to £3000.
    You guys got any ideas how much a wheel bearing is to replace and is it an easy DIY fix?
  23. krisavant
    449
    59
    Cost me £130 at garage supplied and fitted.
    Seems to be a bit common on b6's.
  24. ruffrida
    1,926
    313
    Great news gedi,get some pics on!
    Wheel bearing is not a big job,but you will need some special tools,as kris said it's cheap enough to have a garage do it
  25. glenandem
    glenandem Active Member
    674
    31
    good lad 1.9 tdi 130 best diesel engine vw/audi made in opinion.
    i actually bought mine looking for a 1.9 rather than a 2.0, everythings cheap and easy to replace diy.
    mine had never been looked after when i bought so replaced everything full service,cambelt,fluids and clutch and flywheel and to be honest i paid about £300 for a sachs full kit and fitted it myself on the drive,a few hours to do quite straight forward if your handy with a spanner.
    as its for the wife i wasnt allowed to do too much but remapped it myself with a clone lead and black smoke remap file and it pulls well enough and still get 40's around town, just wish it was a 6 speed on the mway!
    get some pics up pal?
    ruffrida likes this.
  26. TheDriver
    260
    Excellent stuff mate!! Brilliant price too so well done :)
    Defo get some pics up and I hope it provides you many-a-happy-mile of motoring. - Welcome to the club!!!
  27. Gedi69
    Gedi69 V8 Lover
    32
    Cheers guys, I've fallen in love with it already and for a diesel it pulls really well and as for looks...wow sexy lol
    I will get some pics up once I've washed and polished it ;)
  28. TDI-Tuning
    TDI-Tuning Site Sponsor Site Sponsor
    107
    29
    Hi Gedi69,
    Welcome to the forum and congratulations on your new purchase!
    We are a specialist tuning company and forum sponsors. Should you ever require any general advice on tuning your new Audi, then please feel free to contact us for a chat.
    Kind regards,
    Steve
    01245 924 400
    Diesel Tuning | Diesel Engine Tuning | TDI Tuning
    Gedi69 likes this.
  29. Gedi69
    Gedi69 V8 Lover
    32
    Thanks TDI :) funnily enough i was looking at your plug n play remaps as your only 20 mins down the road from me.
    Ive just been remembering what the bloke was chatting about when i brought it and he said something about it being a redeye engine??? what does this mean and what does PD mean also?? are these any good?
  30. quattrojames
    14,046
    571
    Red Eye means its a TDi - hence a 130bhp model.
    Pump Deuse refers to the method of fuel delivery, Google will explain it far better than I.
  31. TDI-Tuning
    107
    29
    Hi Gedi69,
    Great, we are in Chelmsford, Essex (just off Waterhouse Lane). We offer a custom in-house remap and a tuning box for your Audi A4 B6. With both options, you can expect to receive considerable gains in power, torque and economy.
    You are very welcome to drop into our office for a coffee and a chat. We can talk you through all the options available to you. We offer a ‘try before you buy’ service on our tuning boxes. So we could programme a box to meet your specific requirements and then fit it for you. You would then have an opportunity to test the results first hand prior to making a purchase.
    Here’s a link to our PDd tuning box which achieves great results with your vehicle - PDd Diesel Tuning Box - Audi A4 1.9 TDI 128 Bhp / 130 PS / 96 Kw
    Installation is free and ASN members receive a 10% discount. We also offer a 14 day money back guarantee and a 3 year warranty.
    With regards to your questions, the red ‘I’ on your TDI badge means your vehicle has a power rating of 130PS. A chrome ‘I’ would indicate your vehicle has a power rating of 100. ‘PD’ is an abbreviation for pump düse. This refers to the fuel injection technology used on your engine.
    Please do not hesitate to contact us should you require any further help – 01245 924 400 or feel free to drop in.
    Kind regards,
    Steve
  32. Gedi69
    Gedi69 V8 Lover
    32
    Thanks James :(
    Top man Steve thanks for your help and awesome service, I'll be sure to come see you once I've got all the problems with the car sorted first.
    TDI-Tuning likes this.
  33. Gedi69
    Gedi69 V8 Lover
    32
    These pics don't do it justice :(
  34. Gedi69
    Gedi69 V8 Lover
    32
    Just found these buttons hidden in the door pocket, what are they for? image.jpg
    I tried looking in manual but couldn't find them.
  35. quattrojames
    14,046
    571
    If I had £1 for every time.....
    One will disable the interior sensors, for example if you leave a dog in the car. The other disables the anti vibration feature, for example if the vehicle is being moved on a recovery truck.
  36. Gedi69
    Gedi69 V8 Lover
    32
    Cheers James and sorry :(
  37. quattrojames
    14,046
    571
    Lol no need :thumbsup:
  38. ruffrida
    1,926
    313
  39. Gedi69
    Gedi69 V8 Lover
    32
    It's a mettalic Mauritius blue, looks really nice polished up.
